Ir para o conteúdo principal
PDP Victrix Pro BFG Battery and Trigger Replacement
O que você precisa
  1. PDP Victrix Pro BFG Battery and Trigger Replacement, Battery and Trigger: passo 1, imagem 1 %32
    • Use the purple Module Swap Tool that comes with the device to remove the 4 hex screws.
    • Remove the joystick/button modules from the controller.
  2. PDP Victrix Pro BFG Battery and Trigger Replacement: passo 2, imagem 1 %32
    • Remove the screws from each of the module compartments using a PH0 or J1 bit.
  3. PDP Victrix Pro BFG Battery and Trigger Replacement: passo 3, imagem 1 %32 PDP Victrix Pro BFG Battery and Trigger Replacement: passo 3, imagem 2 %32
    • Using the iFixit opening tool, gently pry open the two side grips.
    • Using a PH0 or J1 screwdriver bit with a 4mm diameter or less, remove the screws located in the bottom outside corners.
  4. PDP Victrix Pro BFG Battery and Trigger Replacement: passo 4, imagem 1 %32
    • Flip the controller to the other side so the label on the bottom is facing upwards.
    • On the label, there is a circular icon; this shows the location of a single screw.
    • Using the same PH0 or J1 screwdriver bit from the previous steps, remove the screw.
  5. PDP Victrix Pro BFG Battery and Trigger Replacement: passo 5, imagem 1 %32
    • Flip the controller so the charging port of the controller is facing you.
    • Using a spudger, carefully pry open the front component.
  6. PDP Victrix Pro BFG Battery and Trigger Replacement: passo 6, imagem 1 %32
    • Flip the controller so it is upside-down, but the charging port is still facing you.
    • In the center of the now exposed part, there will be a hidden silver screw.
    • Use the flexible piece attached to the screwdriver to remove this screw.
    • Now that everything is loosened, gently pry open the controller along the grooves.
  7. PDP Victrix Pro BFG Battery and Trigger Replacement: passo 7, imagem 1 %32
    • Using the screwdriver tool with a smaller head, remove the three screws from each trigger.
    • Remove the triggers.
  8. PDP Victrix Pro BFG Battery and Trigger Replacement: passo 8, imagem 1 %32
    • Using the screwdriver, remove the two screws in the bottom two corners.
    • Using the halberd spudger, carefully pry the circuit board open.
  9. PDP Victrix Pro BFG Battery and Trigger Replacement: passo 9, imagem 1 %32
    • To remove the batteries, use a pair of tweezers to carefully unplug the batteries from the circuit board.
Conclusão
4 outras pessoas executaram este guia.
ryanmorabito
Membro desde: 03/20/24
260 Reputação
Autoria de 1 guia
Equipe
5Comentários do guia
Only guide I could find to get this controller apart for my son. Now have to find someone to resolder the USB c port.
Matthew Lash - Responder Compartilhar
R2 and L2 no response, the board location for button?
Terry - Responder Compartilhar
if my remote doesn’t turn on or charge should I change the battery or just throw it away?
Nerdy mom - Responder Compartilhar
How much and how can I buy the battery's?
Dino - Responder Compartilhar
Really sucks that the L2 and R2 modules are all one big thing and not easily repairable. My R2 had a crack near the two screws and I went to Turtle Beach trying to get a replacement. They don't offer parts and I had to resort to superglue. I hope it holds up, but repairability for this controller is pretty low without access to the proprietary parts.
Michael Monn - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 11
Últimos 7 dias: 51
Últimos 30 dias: 225
Ao todo: 6,526
