Ir para o conteúdo principal
PDP Rematch Advanced Triggers Replacement
O que você precisa
  1. PDP Rematch Advanced Triggers Replacement, Triggers: passo 1, imagem 1 %32 PDP Rematch Advanced Triggers Replacement, Triggers: passo 1, imagem 2 %32
    • Orient the controller so the back side is facing you.
    • Use a Phillips #000 screwdriver to remove the seven 9 mm screws that secure the back shell.
  2. PDP Rematch Advanced Triggers Replacement: passo 2, imagem 1 %32 PDP Rematch Advanced Triggers Replacement: passo 2, imagem 2 %32
    • Pull apart the controller's front and back shells with moderate force.
    • Orient the controller so that the front shell is facing the floor to prevent the face buttons from falling out.
  3. PDP Rematch Advanced Triggers Replacement: passo 3, imagem 1 %32 PDP Rematch Advanced Triggers Replacement: passo 3, imagem 2 %32
    • Use a Phillips #00 screwdriver to remove the two 5 mm screws that secure the motherboard.
  4. PDP Rematch Advanced Triggers Replacement: passo 4, imagem 1 %32
    • Remove the motherboard from the back shell using moderate force.
  5. PDP Rematch Advanced Triggers Replacement: passo 5, imagem 1 %32 PDP Rematch Advanced Triggers Replacement: passo 5, imagem 2 %32
    • Use a Phillips #00 screwdriver to remove the two trigger springs from the motherboard.
  6. PDP Rematch Advanced Triggers Replacement: passo 6, imagem 1 %32 PDP Rematch Advanced Triggers Replacement: passo 6, imagem 2 %32
    • Use a hair dryer to remove the trigger from the motherboard.
Conclusão
Kevin Crawford
Membro desde: 09/23/24
133 Reputação
Autoria de 1 guia
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 26
Ao todo: 316
