Ir para o conteúdo principal
PDP Rematch Advanced Back Shell Replacement
O que você precisa
  1. PDP Rematch Advanced Back Shell Replacement, Joystick Cover: passo 1, imagem 1 %32 PDP Rematch Advanced Back Shell Replacement, Joystick Cover: passo 1, imagem 2 %32 PDP Rematch Advanced Back Shell Replacement, Joystick Cover: passo 1, imagem 3 %32
    • Orient the controller so the back side is facing you.
    • Use a Phillips #000 screwdriver to remove the seven 9 mm screws that secure the back shell.
    Pergunte ao FixBot
  2. PDP Rematch Advanced Back Shell Replacement: passo 2, imagem 1 %32 PDP Rematch Advanced Back Shell Replacement: passo 2, imagem 2 %32 PDP Rematch Advanced Back Shell Replacement: passo 2, imagem 3 %32
    • Pull apart the controller's front and back shells with moderate force.
    • Orient the controller so that the front shell is facing the floor to prevent the face buttons from falling out.
    Pergunte ao FixBot
  3. PDP Rematch Advanced Back Shell Replacement: passo 3, imagem 1 %32 PDP Rematch Advanced Back Shell Replacement: passo 3, imagem 2 %32
    • Twist the thumbstick to remove it from the motherboard. Repeat this step if both thumbsticks need to be replaced.
    Pergunte ao FixBot
  4. PDP Rematch Advanced Back Shell Replacement, Back Shell: passo 4, imagem 1 %32 PDP Rematch Advanced Back Shell Replacement, Back Shell: passo 4, imagem 2 %32
    • Grab the motor and pull away from the back shell. Repeat for both motors.
    Pergunte ao FixBot
  5. PDP Rematch Advanced Back Shell Replacement: passo 5, imagem 1 %32 PDP Rematch Advanced Back Shell Replacement: passo 5, imagem 2 %32
    • Use a Phillips #00 Screwdriver to remove the two 5mm screws from the motherboard.
    Pergunte ao FixBot
  6. PDP Rematch Advanced Back Shell Replacement: passo 6, imagem 1 %32 PDP Rematch Advanced Back Shell Replacement: passo 6, imagem 2 %32 PDP Rematch Advanced Back Shell Replacement: passo 6, imagem 3 %32
    • Remove the motherboard from the back shell using moderate force.
    Pergunte ao FixBot
Conclusão
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 5
Últimos 30 dias: 41
Ao todo: 489
