Ir para o conteúdo principal
Conserte seus objetos
Direito de executar reparos
Loja
Introdução
Caution: This guide includes using a soldering iron and can damage your controller or your hand if not used properly.
  1. Loosen the seven 11 mm Phillips #0 screws located on the back of the controller. Loosen the seven 11 mm Phillips #0 screws located on the back of the controller.
    • Loosen the seven 11 mm Phillips #0 screws located on the back of the controller.
  2. Using a plastic opening tool, pry the back cover from the front.
    • Using a plastic opening tool, pry the back cover from the front.
    • The covers should separate without needing a plastic opening tool, but in some cases you may need to use it.
  3. Remove the top cover from the bottom and place next to each other.
    • Remove the top cover from the bottom and place next to each other.
  4. Lift the Logic Board and remove the rumble motors from the base of the controller. Lift the Logic Board and remove the rumble motors from the base of the controller.
    • Lift the Logic Board and remove the rumble motors from the base of the controller.
  5. The rumble motors are located in the bottom right and left hand corners of the controller.
    • The rumble motors are located in the bottom right and left hand corners of the controller.
    • Find where the power (red) wire and ground (black) wire are connected to the logic board. The power (red) wire should be on the left while the black (ground) wire is on the right.
  6. The soldering iron is very hot and can harm you or the device if used improperly.
    • The soldering iron is very hot and can harm you or the device if used improperly.
    • Take the soldering iron after it has been heated up and place it where the ground (black) wire is connected to the logic board.
    • Let it heat up and remove some of the solder with the solder vacuum.
    • Do the same for the power (red) wire.
  7. Now take the new rumble motor and place the power (red) wire on the right hole where the (+) sign is.
    • Now take the new rumble motor and place the power (red) wire on the right hole where the (+) sign is.
    • Take some solder and seal the hole so that the solder is completely covering the (+) hole.
    • Do the same for the ground wire.
Conclusão
Austin Miller
Membro desde: 18/09/2015
171 Reputação
Autoria de 1 guia
Equipe
IUPUI, Team 3-1, Harley Fall 2015 Membro de IUPUI, Team 3-1, Harley Fall 2015
IUPUI-HARLEY-F15S3G1
4 Membros
5 Guias de autoria
Where can I purchase just the rumble motors? I'd like to try adding rumble to a PDP Rock Candy controller, which is essentially the same controller as the AfterGlow but in a neon colored shell and no LED lighting. I don't know if they'll actually work but it would be a fun project.
Josh Koontz - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 34
Duração total: 1,631
