Ir para o conteúdo principal
PDP Afterglow Wired Xbox 360 Controller LEDs Replacement
O que você precisa
  1. PDP Afterglow Wired Xbox 360 Controller LEDs Replacement, Case: passo 1, imagem 1 %32 PDP Afterglow Wired Xbox 360 Controller LEDs Replacement, Case: passo 1, imagem 2 %32
    • Loosen the seven 11 mm Phillips #0 screws located on the back of the controller.
  2. PDP Afterglow Wired Xbox 360 Controller LEDs Replacement: passo 2, imagem 1 %32
    • Using a plastic opening tool, pry the back cover from the front.
    • The covers should separate without needing a plastic opening tool, but in some cases you may need to use it.
  3. PDP Afterglow Wired Xbox 360 Controller LEDs Replacement: passo 3, imagem 1 %32
    • Remove the top cover from the bottom and place next to each other.
  4. PDP Afterglow Wired Xbox 360 Controller LEDs Replacement, LEDs: passo 4, imagem 1 %32 PDP Afterglow Wired Xbox 360 Controller LEDs Replacement, LEDs: passo 4, imagem 2 %32
    • Remove the logic board from the controller casing by lifting up and pulling out.
  5. PDP Afterglow Wired Xbox 360 Controller LEDs Replacement: passo 5, imagem 1 %32
    • Locate the LED (s) that needs to be replaced.
    • Once the LED has been located, flip the logic board to the other side and locate the pins associated with the LED that needs to be replaced.
  6. PDP Afterglow Wired Xbox 360 Controller LEDs Replacement: passo 6, imagem 1 %32
    • Desolder the LED from the logic board.
    • The soldering iron is very hot and can harm you or the device if used improperly.
Conclusão
Uma outra pessoa concluiu este guia.
Joi Officer
Membro desde: 09/17/15
298 Reputação
Autoria de 2 guias
Equipe
IUPUI, Team 3-1, Harley Fall 2015 Membro de IUPUI, Team 3-1, Harley Fall 2015
IUPUI-HARLEY-F15S3G1
4 Membros
Autoria de 5 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 22
Ao todo: 2,252
