Ir para o conteúdo principal
PDP Afterglow Wired Xbox 360 Controller Joysticks Replacement
O que você precisa
  1. PDP Afterglow Wired Xbox 360 Controller Joysticks Replacement, Joysticks: passo 1, imagem 1 %32
    • Remove the two 11 mm screws from the back of the controller using a Phillips #0 screwdriver.
    • Remove the five 8 mm screws from the back of the controller using a Phillips #0 screwdriver.
  2. PDP Afterglow Wired Xbox 360 Controller Joysticks Replacement: passo 2, imagem 1 %32
    • Remove the back cover from the controller and set it aside.
  3. PDP Afterglow Wired Xbox 360 Controller Joysticks Replacement: passo 3, imagem 1 %32
    • Remove the circuit board from the front casing.
    • Be cautious of disconnecting the vibration motors which are attached by thin wires.
  4. PDP Afterglow Wired Xbox 360 Controller Joysticks Replacement: passo 4, imagem 1 %32 PDP Afterglow Wired Xbox 360 Controller Joysticks Replacement: passo 4, imagem 2 %32 PDP Afterglow Wired Xbox 360 Controller Joysticks Replacement: passo 4, imagem 3 %32
    • Wiggle and pull the joystick until it comes off of the circuit board.
  5. PDP Afterglow Wired Xbox 360 Controller Joysticks Replacement: passo 5, imagem 1 %32 PDP Afterglow Wired Xbox 360 Controller Joysticks Replacement: passo 5, imagem 2 %32
    • Place the new joystick into position and press until the joystick makes a click.
  6. PDP Afterglow Wired Xbox 360 Controller Joysticks Replacement: passo 6, imagem 1 %32
    • Place the circuit board and vibration motors back into the front casing.
  7. PDP Afterglow Wired Xbox 360 Controller Joysticks Replacement: passo 7, imagem 1 %32 PDP Afterglow Wired Xbox 360 Controller Joysticks Replacement: passo 7, imagem 2 %32 PDP Afterglow Wired Xbox 360 Controller Joysticks Replacement: passo 7, imagem 3 %32
    • Place the back cover into position.
    • Reinsert the two 11 mm screws into the back of the controller using a Phillips #0 screwdriver.
    • Reinsert the five 8 mm screws into the back of the controller using a Phillips #0 screwdriver.
Linha de Chegada
3 outras pessoas executaram este guia.
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 36
Últimos 30 dias: 132
Ao todo: 4,326
