Ir para o conteúdo principal
PDP Afterglow Wired Xbox 360 Controller Cable Replacement
O que você precisa
  1. PDP Afterglow Wired Xbox 360 Controller Cable Replacement, Case: passo 1, imagem 1 %32 PDP Afterglow Wired Xbox 360 Controller Cable Replacement, Case: passo 1, imagem 2 %32
    • Loosen the seven 11 mm Phillips #0 screws located on the back of the controller.
  2. PDP Afterglow Wired Xbox 360 Controller Cable Replacement: passo 2, imagem 1 %32
    • Using a plastic opening tool, pry the back cover from the front.
    • The covers should separate without needing a plastic opening tool, but in some cases you may need to use it.
  3. PDP Afterglow Wired Xbox 360 Controller Cable Replacement: passo 3, imagem 1 %32
    • Remove the top cover from the bottom and place next to each other.
  4. PDP Afterglow Wired Xbox 360 Controller Cable Replacement, Cable: passo 4, imagem 1 %32 PDP Afterglow Wired Xbox 360 Controller Cable Replacement, Cable: passo 4, imagem 2 %32
    • Remove the logic board by lifting up on the logic board and pulling out.
  5. PDP Afterglow Wired Xbox 360 Controller Cable Replacement: passo 5, imagem 1 %32
    • The cable connects to the logic board with a white connector. Above the right joystick, there are four solder pins labeled GND, VCC, DM, and DP.
  6. PDP Afterglow Wired Xbox 360 Controller Cable Replacement: passo 6, imagem 1 %32
    • The soldering iron is very hot and can harm you or the device if used incorrectly.
    • Desolder the four pins.
  7. PDP Afterglow Wired Xbox 360 Controller Cable Replacement: passo 7, imagem 1 %32
    • Using your new cable, solder the white connector to the logic board. Be sure to have the cables facing towards the inside of the logic board.
Conclusão
5 outras pessoas executaram este guia.
Equipe
IUPUI, Team 3-1, Harley Fall 2015 Membro de IUPUI, Team 3-1, Harley Fall 2015
IUPUI-HARLEY-F15S3G1
Membros da 4
Autoria de 5 guias
4 comentários
where can I find a replacement cable to perform this precedure with?
Aaron English - Responder
yes!! i would like to know too.. i have been searching for long time for that cable
sokratis162 -
Android cable
Wayne -
U can use a old Android cable
Wayne - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 17
Últimos 30 dias: 71
Duração total: 7,068
