Ir para o conteúdo principal
PDP Afterglow Wired Xbox 360 Controller Button Replacement
O que você precisa
  1. PDP Afterglow Wired Xbox 360 Controller Button Replacement, Case: passo 1, imagem 1 %32 PDP Afterglow Wired Xbox 360 Controller Button Replacement, Case: passo 1, imagem 2 %32
    • Loosen the seven 11 mm Phillips #0 screws located on the back of the controller.
  2. PDP Afterglow Wired Xbox 360 Controller Button Replacement: passo 2, imagem 1 %32
    • Using a plastic opening tool, pry the back cover from the front.
    • The covers should separate without needing a plastic opening tool, but in some cases you may need to use it.
  3. PDP Afterglow Wired Xbox 360 Controller Button Replacement: passo 3, imagem 1 %32
    • Remove the top cover from the bottom and place next to each other.
  4. PDP Afterglow Wired Xbox 360 Controller Button Replacement, Button: passo 4, imagem 1 %32
    • Remove the rubber button covers from the A, B, X, and Y buttons.
    What about the rubber cover that's on all the buttons, similar to the rubber cover behind the D-Pad? What orientation is that meant to be in when reassembling the controller after replacing the buttons?
    Rohebat - Responder
  5. PDP Afterglow Wired Xbox 360 Controller Button Replacement: passo 5, imagem 1 %32 PDP Afterglow Wired Xbox 360 Controller Button Replacement: passo 5, imagem 2 %32
    • Push up on the buttons from the front and pull them out from the back.
Conclusão
3 outras pessoas executaram este guia.
Joi Officer
Membro desde: 09/17/15
283 Reputação
Autoria de 2 guias
Equipe
IUPUI, Team 3-1, Harley Fall 2015 Membro de IUPUI, Team 3-1, Harley Fall 2015
IUPUI-HARLEY-F15S3G1
Membros da 4
Autoria de 5 guias
3 comentários
What about removing the Dpad? i really need help.
Elijah Douglas - Responder
I’m sorry but, I have to say that the reassembly process is harder than simply ‘follow the instructions in reverse’; if you try and place the half with the buttons, the buttons fall out or end up misaligned ; and if you use the other half, the rubber covers and the tumblers will fall out.
Again, this guild comes off a little too simple, there’s more to it.
Christopher Mali-Martinez - Responder
the circuit board comes off the other half. You can stack them very easily. You're simply incorrect.
Tyler Anderson -
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 26
Duração total: 4,948
