Ir para o conteúdo principal
PDP Afterglow Fener Speaker Replacement
O que você precisa
  1. PDP Afterglow Fener Speaker Replacement, Speaker: passo 1, imagem 1 %32 PDP Afterglow Fener Speaker Replacement, Speaker: passo 1, imagem 2 %32 PDP Afterglow Fener Speaker Replacement, Speaker: passo 1, imagem 3 %32
    • Gently pull off your left and right ear pad. For further instructions on how to carefully do this please go to this guide here.
    • For each of the red circled screws, take your J000 screwdriver and unscrew the screws.
    • This is a picture of what your headset looks like now that you have done the first two steps.
    • Remove the wire connected in the red box by gently pulling it off.
  2. PDP Afterglow Fener Speaker Replacement: passo 2, imagem 1 %32 PDP Afterglow Fener Speaker Replacement: passo 2, imagem 2 %32 PDP Afterglow Fener Speaker Replacement: passo 2, imagem 3 %32
    • Take your soldering iron and unsolder the wire from the speaker.
    • The red square is the left tip and the orange square is the right tip.
    • Before wiring your new speaker in, clean the left and right tips with your soldering iron.
Conclusão
Thomas Williams
Membro desde: 10/22/15
512 Reputação
Autoria de 4 guias
Equipe
UMass Dartmouth, Team 5-3, Gulbrandsen Fall 2015 Membro de UMass Dartmouth, Team 5-3, Gulbrandsen Fall 2015
UMASSD-GULBRANDSEN-F15S5G3
Membros da 3
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 19
Duração total: 1,554
