Ir para o conteúdo principal
PDP Afterglow Fener LED Replacement
O que você precisa
  1. PDP Afterglow Fener LED Replacement, LED: passo 1, imagem 1 %32 PDP Afterglow Fener LED Replacement, LED: passo 1, imagem 2 %32 PDP Afterglow Fener LED Replacement, LED: passo 1, imagem 3 %32
    • Gently pull off your left and right ear pad. For further instructions on how to carefully do this please go to this guide here.
    • For each of the red circled screws, take your J000 screwdriver and unscrew the screws.
    • This is a picture of what your headset looks like now that you have done the first two steps and have removed the part that you unscrewed.
  2. PDP Afterglow Fener LED Replacement: passo 2, imagem 1 %32 PDP Afterglow Fener LED Replacement: passo 2, imagem 2 %32
    • First remove the battery from the headset, for instructions on how to do this correctly go here
    • Now take your J000 screwdriver and unscrew the screws that have a red circle around them.
    • Now remove the circuit board from the headset and flip it to the other side to be able to see the light/LED.
  3. PDP Afterglow Fener LED Replacement: passo 3, imagem 1 %32 PDP Afterglow Fener LED Replacement: passo 3, imagem 2 %32 PDP Afterglow Fener LED Replacement: passo 3, imagem 3 %32
    • Take your helping hand with alligator clips and put the printed circuit board on it.
    • This picture is a close up of the LED with the highlighted areas you need to unsoldered.
    • Now take your soldering iron and unsolder those four highlighted areas.
    • Your LED should come loose and you can now put on your new LED.
Conclusão
Uma outra pessoa concluiu este guia.
Thomas Williams
Membro desde: 10/22/15
512 Reputação
Autoria de 4 guias
Equipe
UMass Dartmouth, Team 5-3, Gulbrandsen Fall 2015 Membro de UMass Dartmouth, Team 5-3, Gulbrandsen Fall 2015
UMASSD-GULBRANDSEN-F15S5G3
Membros da 3
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 15
Duração total: 850
