Ir para o conteúdo principal
PDP Afterglow Fener Battery Replacement
O que você precisa
  1. PDP Afterglow Fener Battery Replacement, Battery: passo 1, imagem 1 %32 PDP Afterglow Fener Battery Replacement, Battery: passo 1, imagem 2 %32
    • Gently pull off your left and right ear pad. For further instructions on how to carefully do this please go to this guide.
    • For each of the red circled screws, take your J000 screwdriver and unscrew the screws.
  2. PDP Afterglow Fener Battery Replacement: passo 2, imagem 1 %32 PDP Afterglow Fener Battery Replacement: passo 2, imagem 2 %32
    • This shows what your device looks like on the inside behind the part that you just removed from the headset.
    • In the red square is the connection between the battery and the headset.
    • Gently pull the wires that are connected to the white part in the red square.
    • Now that your battery is not connected to anything you can take it out of the headset.
Conclusão
5 outras pessoas executaram este guia.
Murat Terzi
Membro desde: 10/26/15
210 Reputação
Autoria de 1 guia
Equipe
UMass Dartmouth, Team 5-3, Gulbrandsen Fall 2015 Membro de UMass Dartmouth, Team 5-3, Gulbrandsen Fall 2015
UMASSD-GULBRANDSEN-F15S5G3
Membros da 3
Autoria de 10 guias
Um comentário
Broke the headset while doing this “easy process” don’t listen to this method.
Daniel Sumida - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 4
Últimos 30 dias: 10
Duração total: 7,398
