Ir para o conteúdo principal
PCPanel Pro MIDI Controller Knob Replacement
O que você precisa
  1. PCPanel Pro MIDI Controller Knob Replacement, Knob: passo 1, imagem 1 %32 PCPanel Pro MIDI Controller Knob Replacement, Knob: passo 1, imagem 2 %32
    • Unplug the device.
  2. PCPanel Pro MIDI Controller Knob Replacement: passo 2, imagem 1 %32 PCPanel Pro MIDI Controller Knob Replacement: passo 2, imagem 2 %32
    • Turn the affected knobs counter-clockwise until they cannot move anymore.
  3. PCPanel Pro MIDI Controller Knob Replacement: passo 3, imagem 1 %32 PCPanel Pro MIDI Controller Knob Replacement: passo 3, imagem 2 %32 PCPanel Pro MIDI Controller Knob Replacement: passo 3, imagem 3 %32
    • Slowly pull upwards on the knob until it slides off.
    • Not much force needs to be used.
  4. PCPanel Pro MIDI Controller Knob Replacement: passo 4, imagem 1 %32 PCPanel Pro MIDI Controller Knob Replacement: passo 4, imagem 2 %32 PCPanel Pro MIDI Controller Knob Replacement: passo 4, imagem 3 %32
    • Unscrew the fastening screw on the new knob until it is loose.
    • Depending on the knob, you may need to use a different tool to unscrew it. For the knob we had, we used a flathead screwdriver.
  5. PCPanel Pro MIDI Controller Knob Replacement: passo 5, imagem 1 %32 PCPanel Pro MIDI Controller Knob Replacement: passo 5, imagem 2 %32
    • Place the replacement knob onto the MIDI controller.
  6. PCPanel Pro MIDI Controller Knob Replacement: passo 6, imagem 1 %32 PCPanel Pro MIDI Controller Knob Replacement: passo 6, imagem 2 %32 PCPanel Pro MIDI Controller Knob Replacement: passo 6, imagem 3 %32
    • Screw the fastening screw into the MIDI controller. Make sure to leave a 2mm gap between the bottom of the replacement knob and the MIDI controller.
    • In this case, we used calipers to ensure the gap stayed at 2mm, however placing a few pieces of paper underneath the knob will be just fine. We are keeping this gap to ensure that the knob can still be pushed down.
  7. PCPanel Pro MIDI Controller Knob Replacement: passo 7, imagem 1 %32 PCPanel Pro MIDI Controller Knob Replacement: passo 7, imagem 2 %32 PCPanel Pro MIDI Controller Knob Replacement: passo 7, imagem 3 %32
    • Plug in the MIDI controller and test the replacement knob. Ensure the knob can still be turned in either direction as well as pushed down.
  8. PCPanel Pro MIDI Controller Knob Replacement: passo 8, imagem 1 %32
    • Repeat the steps for any replacement knobs needed.
    • Make sure all replaced knobs can still be turned in either direction as well as pushed down.
Conclusão
Make sure all of the knobs function as intended. To remove the knobs and put the old ones on, simply do the steps in reverse.
William Orlopp
Membro desde: 04/15/24
157 Reputação
Autoria de 1 guia
Equipe
UC Davis, Team 1-1, Morris Spring 2024 Membro de UC Davis, Team 1-1, Morris Spring 2024
UCD-MORRIS-S24S1G1
Membros da 3
1 Guia de autoria
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 6
Duração total: 153
