Ir para o conteúdo principal
Ozeri Pronto ZK14-S Panel Removal Replacement
Pré-requisito somente
Este é um guia somente para pré-requisitos! Este guia faz parte de outro procedimento e não deve ser usado sozinho.
O que você precisa
  1. Ozeri Pronto ZK14-S  Panel Removal  Replacement, Panel Removal: passo 1, imagem 1 %32 Ozeri Pronto ZK14-S  Panel Removal  Replacement, Panel Removal: passo 1, imagem 2 %32
    • Twist the plastic plate slowly to the left to pull it away.
  2. Ozeri Pronto ZK14-S  Panel Removal  Replacement: passo 2, imagem 1 %32
    • Lift up the sticker at the bottom where the “Ozeri” logo is to reveal a screw.
    • The sticker does not need to be completely removed.
  3. Ozeri Pronto ZK14-S  Panel Removal  Replacement: passo 3, imagem 1 %32
    • Using a 2.0 Flathead screwdriver, remove the 9.50 mm Phillips head screw under the sticker.
  4. Ozeri Pronto ZK14-S  Panel Removal  Replacement: passo 4, imagem 1 %32 Ozeri Pronto ZK14-S  Panel Removal  Replacement: passo 4, imagem 2 %32
    • Using a 2.0 Flathead screwdriver, remove the two 18.76 mm Phillips head screws in the plate stand.
  5. Ozeri Pronto ZK14-S  Panel Removal  Replacement: passo 5, imagem 1 %32 Ozeri Pronto ZK14-S  Panel Removal  Replacement: passo 5, imagem 2 %32
    • Using a 2.0 Flathead screwdriver, remove the 9.44 mm Phillips head screw on the edge opposite to the LCD screen.
  6. Ozeri Pronto ZK14-S  Panel Removal  Replacement: passo 6, imagem 1 %32
    • Turn the device over so the back panel is facing up.
  7. Ozeri Pronto ZK14-S  Panel Removal  Replacement: passo 7, imagem 1 %32
    • Using the iFixit opening tool, pry off the two rubber stubs on the right side and the two rubber stubs on the left side of the bottom of the device.
  8. Ozeri Pronto ZK14-S  Panel Removal  Replacement: passo 8, imagem 1 %32
    • Using a 2.0 Flathead screwdriver, remove the four 9.46 mm Phillips head screws that were under the rubber stubs.
  9. Ozeri Pronto ZK14-S  Panel Removal  Replacement: passo 9, imagem 1 %32 Ozeri Pronto ZK14-S  Panel Removal  Replacement: passo 9, imagem 2 %32
    • Pry apart the two panels to separate them from each other.
    • Flip the device over so the LCD is facing up. Flip the front panel over on its side.
    • Be careful when separating the panels to avoid damaging the wires they are connected by.
Conclusão
AshleyKreisel
Membro desde: 10/01/15
101 Reputação
Autoria de 1 guia
Equipe
USF Tampa, Team 1-4, Leahy Fall 2015 Membro de USF Tampa, Team 1-4, Leahy Fall 2015
USFT-LEAHY-F15S1G4
4 Membros
Autoria de 5 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Ao todo: 131
