Ir para o conteúdo principal
Overhead Door Remote Battery Replacement
O que você precisa
  1. Overhead Door Remote Battery Replacement, Opening the door: passo 1, imagem 1 %32
    • Insert your screwdriver into the plastic tab, then pull up.
    • Now go to the bottom near where it says Overhead Door and pull up, it should pop up. Once that is open push forward and the top should release
    • Note: It may be easier to use your finger
  2. Overhead Door Remote Battery Replacement, Getting the board out.: passo 2, imagem 1 %32 Overhead Door Remote Battery Replacement, Getting the board out.: passo 2, imagem 2 %32
    • Take your screwdriver and push it into the bottom left corner of the board as shown on the picture. Once you have it in their good, pull up lightly, the board should come up and out.
  3. Overhead Door Remote Battery Replacement, Arming the remote.: passo 3, imagem 1 %32
    • Flip the board over, you should see the battery. Take your screwdriver and push the battery out gently.
    • Take care not to damage anything! Especially the battery!
    • Now that the old battery is out. Put the new one in, Words up.
  4. Overhead Door Remote Battery Replacement, Put the thing together.: passo 4, imagem 1 %32 Overhead Door Remote Battery Replacement, Put the thing together.: passo 4, imagem 2 %32
    • Now flip the board over and put it in it’s case. You should feel a light click. Remember not to be too hard.
    • When you got the board on, simply take the top part, be mindful of the rubber, and snap it on, the top first then the bottom. You can use the pictures above if you don’t know where it is
    • Note: It will take you a bit of time to get the shell back together, be patient and you will get it.
Conclusão
There you go! A fully functioning remote. Give yourself a pat on the back and go get a drink of water.
Repair Skeleton
Membro desde: 08/23/21
830 Reputação
Autoria de 1 guia
0 comentários
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 26
Últimos 30 dias: 104
Ao todo: 2,638
