Ir para o conteúdo principal
Outdoor Gate Deadbolt Replacement
O que você precisa
  1. Outdoor Gate Deadbolt Replacement, Deadbolt: passo 1, imagem 1 %32 Outdoor Gate Deadbolt Replacement, Deadbolt: passo 1, imagem 2 %32 Outdoor Gate Deadbolt Replacement, Deadbolt: passo 1, imagem 3 %32
    • Remove the old deadbolt.
    • The gate should look like this prior to beginning.
  2. Outdoor Gate Deadbolt Replacement: passo 2, imagem 1 %32 Outdoor Gate Deadbolt Replacement: passo 2, imagem 2 %32 Outdoor Gate Deadbolt Replacement: passo 2, imagem 3 %32
    • Begin pushing the latch inward from the front face of the bolts.
    • Adjust the inside by holding it with both fingers.
    • Begin to screw both of the short screws into our middle side area of the latch.
  3. Outdoor Gate Deadbolt Replacement: passo 3, imagem 1 %32 Outdoor Gate Deadbolt Replacement: passo 3, imagem 2 %32 Outdoor Gate Deadbolt Replacement: passo 3, imagem 3 %32
    • Grab both of the long screws.
    • Adjust the back head of the doorknob to be facing in a straight upward position.
    • Once everything is positioned right, begin screwing in the long screws.
    • Make sure the screws are properly tightened.
  4. Outdoor Gate Deadbolt Replacement: passo 4, imagem 1 %32 Outdoor Gate Deadbolt Replacement: passo 4, imagem 2 %32 Outdoor Gate Deadbolt Replacement: passo 4, imagem 3 %32
    • Allow the back end of the doorknob to be properly aligned with the front head when attaching.
    • Once both parts are attached and alined begin screwing in the screws fully inwards.
  5. Outdoor Gate Deadbolt Replacement: passo 5, imagem 1 %32 Outdoor Gate Deadbolt Replacement: passo 5, imagem 2 %32
    • Now that the new doorknob has been attached, begin testing it out with a key or door handle depending on which one you may have.
Conclusão
Kenneth
Membro desde: 03/20/24
121 Reputação
Autoria de 1 guia
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 14
Últimos 30 dias: 87
Duração total: 133
