Ir para o conteúdo principal
Ottlite PL-0094 Lamp Switch Replacement
O que você precisa
  1. Ottlite PL-0094 Lamp Switch Replacement, Remove Switch: passo 1, imagem 1 %32
    • Lay lamp on its side and remove the 2 screws between the lower and upper lamp posts. Gently pull the 2 sections apart a few inches. Slide the plastic switch cover off by sliding upwards.
    • Remove the 2 screws holding the USB port circuit board to the cover.
    • With utility blade, carefully cut the 2 plastic mounts for the touch switch circuit board and remove from cover.
    • The small flat on/off button should fall out also.
    Pergunte ao FixBot
    Comentar
  2. Ottlite PL-0094 Lamp Switch Replacement, Mount New Switch: passo 2, imagem 1 %32
    • I mounted the new switch in the location of the old switch button. There is a hole mostly there already if you just cut the remaining plastic to leave about a 3/8" hole.
    • You'll need to trim down the small plastic posts that held the switch circuit board in place.
    • The switch doesn't have a lot of threads, so you can't use thick washers. I used a 5/16" speed nut on the inside, which also helps keep the switch centered since hole is a little bit bigger than needed.
    • On the outside I used a thin plastic washer, then the nut for the switch.
    • Bend the tabs down as pictured so wiring will fit when reassembled. Tighten nut.
    Pergunte ao FixBot
    Comentar
  3. Ottlite PL-0094 Lamp Switch Replacement, Wiring: passo 3, imagem 1 %32 Ottlite PL-0094 Lamp Switch Replacement, Wiring: passo 3, imagem 2 %32
    • Since the the touch switch doesn't work, we discard that circuit board. Cut the 4 wires at the circuit board.
    • I soldered my wires together and covered with shrink tubing. I suppose you could use good insulated wire connectors instead.
    • Connect the 2 black wires together, the one from the USB board to the one going to the lamps.
    • Connect the red wire from the USB board to one of the switch wires. I used the red switch wire.
    • Connect the other wire from the switch to the white wire going to the lamps.
    • Screw the USB board back in place.
    Pergunte ao FixBot
    Comentar
    • Feed the wires back up into the lamp post holes. Fold wires so they fit inside cover as you slide the cover back in place.
    • Fit the 2 lamp posts together and install the 2 screws to hold them together.
    • Plug in, and hopefully your light now works.
    Pergunte ao FixBot
    Comentar
Conclusão
Enjoy!
Uma outra pessoa concluiu este guia.
KenF
Membro desde: 10/31/23
139 Reputação
Autoria de 1 guia
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 8
Últimos 30 dias: 80
Ao todo: 1,453
