Ir para o conteúdo principal
Oster Expressbake CKSTBRTW20 Top Panel Buttons Replacement
O que você precisa
  1. Oster Expressbake CKSTBRTW20 Top Panel Buttons Replacement, Top Panel Removal: passo 1, imagem 1 %32
    • Remove the bread pan.
  2. Oster Expressbake CKSTBRTW20 Top Panel Buttons Replacement: passo 2, imagem 1 %32 Oster Expressbake CKSTBRTW20 Top Panel Buttons Replacement: passo 2, imagem 2 %32 Oster Expressbake CKSTBRTW20 Top Panel Buttons Replacement: passo 2, imagem 3 %32
    • Remove the eight 22mm Phillips #1 screws from the grey lining.
    • Remove the grey liner.
  3. Oster Expressbake CKSTBRTW20 Top Panel Buttons Replacement: passo 3, imagem 1 %32 Oster Expressbake CKSTBRTW20 Top Panel Buttons Replacement: passo 3, imagem 2 %32
    • Remove the two 11mm Phillips #1 screws from the back of the device.
  4. Oster Expressbake CKSTBRTW20 Top Panel Buttons Replacement: passo 4, imagem 1 %32 Oster Expressbake CKSTBRTW20 Top Panel Buttons Replacement: passo 4, imagem 2 %32
    • Pop off the top case using a spudger.
    • Keep the spudger away from the control panel.
    • Be aware of wires connecting the microcontroller to the panel when removing the top lining.
  5. Oster Expressbake CKSTBRTW20 Top Panel Buttons Replacement, Top Panel Buttons: passo 5, imagem 1 %32 Oster Expressbake CKSTBRTW20 Top Panel Buttons Replacement, Top Panel Buttons: passo 5, imagem 2 %32 Oster Expressbake CKSTBRTW20 Top Panel Buttons Replacement, Top Panel Buttons: passo 5, imagem 3 %32
    • Disconnect microcontroller and top lining.
    • Ground yourself prior to disconnecting in order to avoid harming the inner electronics.
  6. Oster Expressbake CKSTBRTW20 Top Panel Buttons Replacement: passo 6, imagem 1 %32 Oster Expressbake CKSTBRTW20 Top Panel Buttons Replacement: passo 6, imagem 2 %32
    • Remove the two 11mm Phillips #1 screws from the top cover.
  7. Oster Expressbake CKSTBRTW20 Top Panel Buttons Replacement: passo 7, imagem 1 %32
    • Use spudger to pop the control panel out.
  8. Oster Expressbake CKSTBRTW20 Top Panel Buttons Replacement: passo 8, imagem 1 %32 Oster Expressbake CKSTBRTW20 Top Panel Buttons Replacement: passo 8, imagem 2 %32 Oster Expressbake CKSTBRTW20 Top Panel Buttons Replacement: passo 8, imagem 3 %32
    • Remove the four 11mm Phillips #1 screws from the control panel.
  9. Oster Expressbake CKSTBRTW20 Top Panel Buttons Replacement: passo 9, imagem 1 %32 Oster Expressbake CKSTBRTW20 Top Panel Buttons Replacement: passo 9, imagem 2 %32 Oster Expressbake CKSTBRTW20 Top Panel Buttons Replacement: passo 9, imagem 3 %32
    • Remove the two 11mm Phillips #1 screws from the button panel.
    • Flip the screen assembly over and remove the button panel.
  10. Oster Expressbake CKSTBRTW20 Top Panel Buttons Replacement: passo 10, imagem 1 %32 Oster Expressbake CKSTBRTW20 Top Panel Buttons Replacement: passo 10, imagem 2 %32
    • Remove and replace buttons as necessary.
Conclusão
Megan Saunders
Membro desde: 01/25/18
701 Reputação
Autoria de 5 guias
Equipe
USF Tampa, Team S7-G5, Passmore Spring 2018 Membro de USF Tampa, Team S7-G5, Passmore Spring 2018
USFT-PASSMORE-S18S7G5
Membros da 4
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 226
