Ir para o conteúdo principal
Oster Expressbake CKSTBRTW20 Heating Coils Replacement
O que você precisa
  1. Oster Expressbake CKSTBRTW20 Heating Coils Replacement, Top Panel Removal: passo 1, imagem 1 %32
    • Remove the bread pan.
  2. Oster Expressbake CKSTBRTW20 Heating Coils Replacement: passo 2, imagem 1 %32 Oster Expressbake CKSTBRTW20 Heating Coils Replacement: passo 2, imagem 2 %32 Oster Expressbake CKSTBRTW20 Heating Coils Replacement: passo 2, imagem 3 %32
    • Remove the eight 22mm Phillips #1 screws from the grey lining.
    • Remove the grey liner.
  3. Oster Expressbake CKSTBRTW20 Heating Coils Replacement: passo 3, imagem 1 %32 Oster Expressbake CKSTBRTW20 Heating Coils Replacement: passo 3, imagem 2 %32
    • Remove the two 11mm Phillips #1 screws from the back of the device.
  4. Oster Expressbake CKSTBRTW20 Heating Coils Replacement: passo 4, imagem 1 %32 Oster Expressbake CKSTBRTW20 Heating Coils Replacement: passo 4, imagem 2 %32
    • Pop off the top case using a spudger.
    • Keep the spudger away from the control panel.
    • Be aware of wires connecting the microcontroller to the panel when removing the top lining.
  5. Oster Expressbake CKSTBRTW20 Heating Coils Replacement, Inner Chamber: passo 5, imagem 1 %32 Oster Expressbake CKSTBRTW20 Heating Coils Replacement, Inner Chamber: passo 5, imagem 2 %32 Oster Expressbake CKSTBRTW20 Heating Coils Replacement, Inner Chamber: passo 5, imagem 3 %32
    • Disconnect microcontroller and top lining.
    • Ground yourself prior to disconnecting in order to avoid harming the inner electronics.
  6. Oster Expressbake CKSTBRTW20 Heating Coils Replacement: passo 6, imagem 1 %32 Oster Expressbake CKSTBRTW20 Heating Coils Replacement: passo 6, imagem 2 %32 Oster Expressbake CKSTBRTW20 Heating Coils Replacement: passo 6, imagem 3 %32
    • Remove the four 11mm Phillips #1 screws holding from the guard and inner lining.
    • Remove small rectangular guard from bottom of liner
  7. Oster Expressbake CKSTBRTW20 Heating Coils Replacement: passo 7, imagem 1 %32
    • Remove the inner liner.
    • The inner liner will be connected to the outer chamber with wires.
  8. Oster Expressbake CKSTBRTW20 Heating Coils Replacement: passo 8, imagem 1 %32 Oster Expressbake CKSTBRTW20 Heating Coils Replacement: passo 8, imagem 2 %32 Oster Expressbake CKSTBRTW20 Heating Coils Replacement: passo 8, imagem 3 %32
    • Disconnect the red wires from the inner liner.
  9. Oster Expressbake CKSTBRTW20 Heating Coils Replacement: passo 9, imagem 1 %32 Oster Expressbake CKSTBRTW20 Heating Coils Replacement: passo 9, imagem 2 %32
    • Remove the single 11mm Phillips #1 screw thats holding and inner lining in place.
  10. Oster Expressbake CKSTBRTW20 Heating Coils Replacement: passo 10, imagem 1 %32 Oster Expressbake CKSTBRTW20 Heating Coils Replacement: passo 10, imagem 2 %32 Oster Expressbake CKSTBRTW20 Heating Coils Replacement: passo 10, imagem 3 %32
    • Use a spudger to push out the connector found on the inner lining.
  11. Oster Expressbake CKSTBRTW20 Heating Coils Replacement: passo 11, imagem 1 %32 Oster Expressbake CKSTBRTW20 Heating Coils Replacement: passo 11, imagem 2 %32
    • Remove lining.
  12. Oster Expressbake CKSTBRTW20 Heating Coils Replacement, Heating Coils: passo 12, imagem 1 %32 Oster Expressbake CKSTBRTW20 Heating Coils Replacement, Heating Coils: passo 12, imagem 2 %32 Oster Expressbake CKSTBRTW20 Heating Coils Replacement, Heating Coils: passo 12, imagem 3 %32
    • Remove the two 11mm Phillips #1 screws from the inside of the chamber.
    • Removal of the screws may also require a 1/4 socket wrench on the other side to prevent spinning.
  13. Oster Expressbake CKSTBRTW20 Heating Coils Replacement: passo 13, imagem 1 %32 Oster Expressbake CKSTBRTW20 Heating Coils Replacement: passo 13, imagem 2 %32 Oster Expressbake CKSTBRTW20 Heating Coils Replacement: passo 13, imagem 3 %32
    • Remove the 11mm Phillips #1 screw from the heating coil.
    • After you have removed the screw the coils will pop out of place.
Conclusão
Uma outra pessoa concluiu este guia.
Megan Saunders
Membro desde: 01/25/18
701 Reputação
Autoria de 5 guias
Equipe
USF Tampa, Team S7-G5, Passmore Spring 2018 Membro de USF Tampa, Team S7-G5, Passmore Spring 2018
USFT-PASSMORE-S18S7G5
Membros da 4
Autoria de 5 guias
Um comentário
We odered a new element but when we took the maker apart one of the leads was not attached. The maker had “walked” off our slick countertop and we think that is when the lead came off. We cleaned the felt pads and put silicone pads on top of those and now it stays stationary. Thank you for this tutorial. Love being able to fix things instead of tossing them. We have repaired our dishwasher twice and even the microwave. Freedom to repair is vital.
Laurie L Sippel - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Duração total: 466
