Ir para o conteúdo principal
Oster Blend-N-Go My Blend Drinking Lid Seal Replacement
O que você precisa
  1. Oster Blend-N-Go My Blend Drinking Lid Seal Replacement, Blender Bottle: passo 1, imagem 1 %32 Oster Blend-N-Go My Blend Drinking Lid Seal Replacement, Blender Bottle: passo 1, imagem 2 %32
    • Grip the blender base with one hand and blender bottle with the other hand.
    • Rotate the blender bottle a quarter turn counterclockwise .
    • Lift the blender bottle out of the blender base. The blade assembly should still be attached to the blender bottle.
  2. Oster Blend-N-Go My Blend Drinking Lid Seal Replacement: passo 2, imagem 1 %32 Oster Blend-N-Go My Blend Drinking Lid Seal Replacement: passo 2, imagem 2 %32 Oster Blend-N-Go My Blend Drinking Lid Seal Replacement: passo 2, imagem 3 %32
    • Grip the blade assembly with one hand and blender bottle with the other hand.
    • Rotate the blade assembly counterclockwise until it is completely unscrewed from the blender bottle.
    • Lift the blender bottle to separate it from the blade assembly.
  3. Oster Blend-N-Go My Blend Drinking Lid Seal Replacement, Drinking Lid Assembly: passo 3, imagem 1 %32
    • After removing the blade assembly from the blender bottle, ensure that your drinking lid assembly has its seal placed in the seal bed.
  4. Oster Blend-N-Go My Blend Drinking Lid Seal Replacement: passo 4, imagem 1 %32 Oster Blend-N-Go My Blend Drinking Lid Seal Replacement: passo 4, imagem 2 %32 Oster Blend-N-Go My Blend Drinking Lid Seal Replacement: passo 4, imagem 3 %32
    • Grab the blender bottle with one hand and the drinking lid assembly with the other.
    • Place the drinking lid assembly onto the blender bottle and twist it clockwise until it is tight around the blender bottle.
  5. Oster Blend-N-Go My Blend Drinking Lid Seal Replacement, Drinking Lid Seal: passo 5, imagem 1 %32
    • After separating the drinking lid assembly from the blender bottle, position the plastic opening tool on either side of the seal in the drinking lid assembly.
    • Wedge the tool between seal and seal seat wall.
  6. Oster Blend-N-Go My Blend Drinking Lid Seal Replacement: passo 6, imagem 1 %32 Oster Blend-N-Go My Blend Drinking Lid Seal Replacement: passo 6, imagem 2 %32
    • Gently pry the seal up while lifting seal out of the seal seat.
  7. Oster Blend-N-Go My Blend Drinking Lid Seal Replacement: passo 7, imagem 1 %32 Oster Blend-N-Go My Blend Drinking Lid Seal Replacement: passo 7, imagem 2 %32
    • Press new seal into seal seat with finger.
Conclusão
Uma outra pessoa concluiu este guia.
Paul Long
Membro desde: 08/27/15
710 Reputação
Autoria de 4 guias
Equipe
USF Tampa, Team 12-6, Blackwell Fall 2015 Membro de USF Tampa, Team 12-6, Blackwell Fall 2015
USFT-BLACKWELL-F15S12G6
Membros da 3
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 12
Duração total: 855
