Ir para o conteúdo principal
Oster Blend-N-Go My Blend Blade Assembly Seal Replacement
O que você precisa
  1. Oster Blend-N-Go My Blend Blade Assembly Seal Replacement, Blender Bottle: passo 1, imagem 1 %32 Oster Blend-N-Go My Blend Blade Assembly Seal Replacement, Blender Bottle: passo 1, imagem 2 %32
    • Grip the blender base with one hand and blender bottle with the other hand.
    • Rotate the blender bottle a quarter turn counterclockwise .
    • Lift the blender bottle out of the blender base. The blade assembly should still be attached to the blender bottle.
  2. Oster Blend-N-Go My Blend Blade Assembly Seal Replacement: passo 2, imagem 1 %32 Oster Blend-N-Go My Blend Blade Assembly Seal Replacement: passo 2, imagem 2 %32 Oster Blend-N-Go My Blend Blade Assembly Seal Replacement: passo 2, imagem 3 %32
    • Grip the blade assembly with one hand and blender bottle with the other hand.
    • Rotate the blade assembly counterclockwise until it is completely unscrewed from the blender bottle.
    • Lift the blender bottle to separate it from the blade assembly.
  3. Oster Blend-N-Go My Blend Blade Assembly Seal Replacement, Blade Assembly: passo 3, imagem 1 %32
    • After removing the blade assembly from the blender bottle, ensure your blade assembly has its seal placed in the seal bed.
  4. Oster Blend-N-Go My Blend Blade Assembly Seal Replacement, Blade Assembly Seal: passo 4, imagem 1 %32
    • After separating the blade assembly from the blender bottle, position the plastic opening tool on either side of the seal in the blade assembly.
    • Wedge tool between seal and seal seat wall.
  5. Oster Blend-N-Go My Blend Blade Assembly Seal Replacement: passo 5, imagem 1 %32
    • Gently pry the seal up while lifting seal out of the seal seat.
  6. Oster Blend-N-Go My Blend Blade Assembly Seal Replacement: passo 6, imagem 1 %32 Oster Blend-N-Go My Blend Blade Assembly Seal Replacement: passo 6, imagem 2 %32
    • Place and press the new seal into seal seat with finger.
Conclusão
3 outras pessoas executaram este guia.
Paul Long
Membro desde: 08/27/15
710 Reputação
Autoria de 4 guias
Equipe
USF Tampa, Team 12-6, Blackwell Fall 2015 Membro de USF Tampa, Team 12-6, Blackwell Fall 2015
USFT-BLACKWELL-F15S12G6
Membros da 3
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 15
Duração total: 1,933
