Ir para o conteúdo principal
Oster BLSTSS-PZO Power Cord Replacement
O que você precisa
  1. Oster BLSTSS-PZO  Power Cord Replacement, Circuitboard: passo 1, imagem 1 %32
    • Use the prying tools to open the four plastic screw holes on the bottom of the blender.
  2. Oster BLSTSS-PZO  Power Cord Replacement: passo 2, imagem 1 %32
    • Use the Phillips #1 Screwdriver to unscrew the four 16 mm screws and remove the plastic bottom.
  3. Oster BLSTSS-PZO  Power Cord Replacement: passo 3, imagem 1 %32
    • Gently remove the circuit board.
  4. Oster BLSTSS-PZO  Power Cord Replacement: passo 4, imagem 1 %32 Oster BLSTSS-PZO  Power Cord Replacement: passo 4, imagem 2 %32
    • Use the spudger to detach the black wire from the circuit board.
    • Repeat for yellow wire.
  5. Oster BLSTSS-PZO  Power Cord Replacement: passo 5, imagem 1 %32 Oster BLSTSS-PZO  Power Cord Replacement: passo 5, imagem 2 %32 Oster BLSTSS-PZO  Power Cord Replacement: passo 5, imagem 3 %32
    • Use the Phillips #1 to remove the four 8mm screws.
    • Use the medal spudger to detach the circuit board from the buttons.
    • Gently pull and release circuit board from buttons.
  6. Oster BLSTSS-PZO  Power Cord Replacement, Power Cord: passo 6, imagem 1 %32 Oster BLSTSS-PZO  Power Cord Replacement, Power Cord: passo 6, imagem 2 %32 Oster BLSTSS-PZO  Power Cord Replacement, Power Cord: passo 6, imagem 3 %32
    • Locate petal prong on the end of the power cord.
    • Bend metal prong until it's straight with your finger.
  7. Oster BLSTSS-PZO  Power Cord Replacement: passo 7, imagem 1 %32 Oster BLSTSS-PZO  Power Cord Replacement: passo 7, imagem 2 %32
    • Spring will pop out when you pull out metal prong
    • Pull prong out of the hole.
  8. Oster BLSTSS-PZO  Power Cord Replacement: passo 8, imagem 1 %32 Oster BLSTSS-PZO  Power Cord Replacement: passo 8, imagem 2 %32 Oster BLSTSS-PZO  Power Cord Replacement: passo 8, imagem 3 %32
    • Pinch plastic prongs on base of blender to remove plastic securing device.
    • Remove plastic securing device.
    • Pull power cord out of blender base.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 2
Últimos 30 dias: 6
Duração total: 208
