O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
Using the Phillips-head #2 screwdriver, unscrew the three 1cm Phillips-head screws on the plastic base of the toaster to separate the outer metal shell from the plastic base.
Push the plastic push-down handle down and pull the plastic handle straight from metal arm.
Loosen the outer metal shell from the plastic base by holding the plastic base while pulling up on the metal shell.
Ferramenta utilizada nesse passo:Tweezers$4.99-
Disconnect the cable clips from the circuit board using the tweezers to free the outer metal shell from the plastic base.
