Ir para o conteúdo principal
Oster 6329 Outer Shell Removal
O que você precisa
  1. Oster 6329 Outer Shell Removal, Outer Shell Removal: passo 1, imagem 1 %32 Oster 6329 Outer Shell Removal, Outer Shell Removal: passo 1, imagem 2 %32
    • Using the Phillips-head #2 screwdriver, unscrew the three 1cm Phillips-head screws on the plastic base of the toaster to separate the outer metal shell from the plastic base.
  2. Oster 6329 Outer Shell Removal: passo 2, imagem 1 %32
    • Push the plastic push-down handle down and pull the plastic handle straight from metal arm.
  3. Oster 6329 Outer Shell Removal: passo 3, imagem 1 %32
    • Loosen the outer metal shell from the plastic base by holding the plastic base while pulling up on the metal shell.
    • Only lift the outer shell a little so as not to disconnect the cables that connect the circuit board.
  4. Oster 6329 Outer Shell Removal: passo 4, imagem 1 %32 Oster 6329 Outer Shell Removal: passo 4, imagem 2 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Disconnect the cable clips from the circuit board using the tweezers to free the outer metal shell from the plastic base.
  5. Oster 6329 Outer Shell Removal: passo 5, imagem 1 %32 Oster 6329 Outer Shell Removal: passo 5, imagem 2 %32
    • Lift the top outer metal shell.
    • Carefully lift the outer metal shell at an angle so as not to damage the components in the front of the toaster.
Conclusão
Isaac Williams
Membro desde: 01/24/14
225 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 13-15, Regan Winter 2014 Membro de Cal Poly, Team 13-15, Regan Winter 2014
CPSU-REGAN-W14S13G15
Membros da 5
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 18
Duração total: 1,978
