Ir para o conteúdo principal
Oster 3905 Lever Spring Replacement
O que você precisa
  1. Oster 3905 Lever Spring Replacement, Slot Levers: passo 1, imagem 1 %32
    • Firmly grip your hand around the slot lever.
  2. Oster 3905 Lever Spring Replacement: passo 2, imagem 1 %32
    • Stabilize the toaster by placing your hand on top.
  3. Oster 3905 Lever Spring Replacement: passo 3, imagem 1 %32 Oster 3905 Lever Spring Replacement: passo 3, imagem 2 %32
    • Forcefully pull the slot lever away from the toaster by keeping parallel to the table.
  4. Oster 3905 Lever Spring Replacement: passo 4, imagem 1 %32
    • Both slot levers can be removed.
  5. Oster 3905 Lever Spring Replacement, Outer Shell: passo 5, imagem 1 %32
    • Place the toaster upside down so the bottom is facing the ceiling.
  6. Oster 3905 Lever Spring Replacement: passo 6, imagem 1 %32 Oster 3905 Lever Spring Replacement: passo 6, imagem 2 %32
    • Take off both rubber feet using a small metal spudger.
    • Wedge a spudger under the feet and pull up to pop off.
  7. Oster 3905 Lever Spring Replacement: passo 7, imagem 1 %32
    • Use a PH#2 screw bit to remove eight 12mm screws that are located around the perimeter.
    • There are two screws under the rubber feet.
  8. Oster 3905 Lever Spring Replacement: passo 8, imagem 1 %32
    • Place the toaster right side up.
  9. Oster 3905 Lever Spring Replacement: passo 9, imagem 1 %32 Oster 3905 Lever Spring Replacement: passo 9, imagem 2 %32
    • Grab the outer shell firmly and pull up towards the face of the toaster.
  10. Oster 3905 Lever Spring Replacement: passo 10, imagem 1 %32
    • For this part, you might need to wiggle the toaster to get the outer shell off.
    • The shell will not completely come off until the motherboard is removed in the next step.
  11. Oster 3905 Lever Spring Replacement: passo 11, imagem 1 %32 Oster 3905 Lever Spring Replacement: passo 11, imagem 2 %32 Oster 3905 Lever Spring Replacement: passo 11, imagem 3 %32
    • Use a J1 screw bit to unscrew eight 8mm screws from the motherboard.
  12. Oster 3905 Lever Spring Replacement: passo 12, imagem 1 %32 Oster 3905 Lever Spring Replacement: passo 12, imagem 2 %32
    • Take out the grey “cancel” and “bagel” buttons from the shell.
  13. Oster 3905 Lever Spring Replacement, Lever Spring: passo 13, imagem 1 %32 Oster 3905 Lever Spring Replacement, Lever Spring: passo 13, imagem 2 %32
    • Use the plastic opening tool to remove the top metal panel by prying the 4 top metal tabs upwards. They will be able to slide through the openings and be pulled upwards.
  14. Oster 3905 Lever Spring Replacement: passo 14, imagem 1 %32 Oster 3905 Lever Spring Replacement: passo 14, imagem 2 %32
    • Once the top metal panel is unhooked, lift and let it hang off the side of the toaster.
  15. Oster 3905 Lever Spring Replacement: passo 15, imagem 1 %32 Oster 3905 Lever Spring Replacement: passo 15, imagem 2 %32 Oster 3905 Lever Spring Replacement: passo 15, imagem 3 %32
    • Use a metal spudger to pry the 8 tabs upwards along the metal that separates the two slots.
    • Pull the metal spacer upwards to release from the toaster.
  16. Oster 3905 Lever Spring Replacement: passo 16, imagem 1 %32 Oster 3905 Lever Spring Replacement: passo 16, imagem 2 %32
    • Remove the spring wrapped around a metal rod at the front of the toaster, located behind the white plastic lever holder.
Conclusão
Uma outra pessoa concluiu este guia.
Sydney Alcaraz
Membro desde: 09/12/16
601 Reputação
Autoria de 3 guias
Equipe
CSU Fullerton, Team 2-1, Bruce Fall 2016 Membro de CSU Fullerton, Team 2-1, Bruce Fall 2016
CSUF-BRUCE-F16S2G1
Membros da 5
Autoria de 6 guias
2 comentários
Where's the fix?
D Unger - Responder
Yeah. You just remove the spring? And then what? Surely removing the spring is not the fix.
kryshu - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 7
Últimos 30 dias: 37
Duração total: 3,011
