O que você precisa
Firmly grip the knob of the toaster, and pull it away from the body.
The three circuit boards all take in user input from buttons or a dial. The button inputs affect the volume of current flowing through the heating elements. The dial controls the time that the heating elements are receiving current. The cancel button releases the mechanical switch.
The switch in picture 2 is pressed down by the user, then held down mechanically. The time it is down is determined by the dial or whether the cancel button is pressed. The switch connects the current to the heating elements.
The heating elements are each 35 ohms. When the switch is connected, they convert the electrical current within them into heat projected outward toward the toast.
Uma outra pessoa concluiu este guia.
