Ir para o conteúdo principal
Osmo Mobile Handle Disassembly
O que você precisa
  1. Osmo Mobile Handle Disassembly, Osmo Mobile Handle Disassembly: passo 1, imagem 1 %32 Osmo Mobile Handle Disassembly, Osmo Mobile Handle Disassembly: passo 1, imagem 2 %32
    • Remove gimbal from base handle by loosening round plate found at the top of the handle.
  2. Osmo Mobile Handle Disassembly: passo 2, imagem 1 %32 Osmo Mobile Handle Disassembly: passo 2, imagem 2 %32
    • Use Phillips #00 screwdriver to remove the three screws found on the gimbal stabilizer to detach handle from gimbal.
    • Carefully detach handle from gimbal and disconnect the cable that connects the two.
  3. Osmo Mobile Handle Disassembly: passo 3, imagem 1 %32
    • Locate the hex screws found at the top base of the handle, and unscrew using the 1.5mm hex screwdriver.
  4. Osmo Mobile Handle Disassembly: passo 4, imagem 1 %32 Osmo Mobile Handle Disassembly: passo 4, imagem 2 %32
    • Remove joystick by gently pulling away from handle
  5. Osmo Mobile Handle Disassembly: passo 5, imagem 1 %32 Osmo Mobile Handle Disassembly: passo 5, imagem 2 %32 Osmo Mobile Handle Disassembly: passo 5, imagem 3 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Remove the quick release PCBA by locating the connecting wires and release the ribbon cable with tweezers.
    • Use the spudger to pry open and remove the face plate, starting at the back of the handle.
  6. Osmo Mobile Handle Disassembly: passo 6, imagem 1 %32 Osmo Mobile Handle Disassembly: passo 6, imagem 2 %32 Osmo Mobile Handle Disassembly: passo 6, imagem 3 %32
    • Locate four screws directly on top of handle.
    • Unscrew the silver, bottom two screws, that are closest to the face plate using the 00 screwdriver.
    • Unscrew the black, top two screws, located furthest from the face plate, using the 0 screwdriver.
    • Remove the remaining two screws found on the front of the faceplate.
    • Remove the rest of the face plate shell.
Conclusão
3 outras pessoas executaram este guia.
Ustena Safa
Membro desde: 09/28/17
345 Reputação
Autoria de 2 guias
Equipe
USF Tampa, Team S2-G1, Nance Fall 2017 Membro de USF Tampa, Team S2-G1, Nance Fall 2017
USFT-NANCE-F17S2G1
Membros da 4
Autoria de 12 guias
10 comentários
Bonjour,
La toute première étape est trop vague pouvez-vous donner plus de détails svp.
Je vous remercie d’avance
Guitt97ii - Responder
I would not call that a handle disassembly. This instruction takes you up to the things you need to do PRIOR to disassembly.
I can show you the rest in a video format if you’re interested
John M O'Donovan - Responder
Could you please show me how to fix the USB port that wenr inside the handle? on my Smove gimbal stabilizer
Juan Carlos Beltran -
My osmo has snapped off at the metal camera attachment. Can this be repaired ?
michelle Moore - Responder
Your help would be greatly appreciated
Emile Jansen -
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 13
Últimos 30 dias: 74
Duração total: 8,078
