Ir para o conteúdo principal
Osmo Mobile Charging Port Replacement
O que você precisa
  1. Osmo Mobile Charging Port Replacement, Osmo Mobile Handle Disassembly: passo 1, imagem 1 %32 Osmo Mobile Charging Port Replacement, Osmo Mobile Handle Disassembly: passo 1, imagem 2 %32
    • Remove gimbal from base handle by loosening round plate found at the top of the handle.
  2. Osmo Mobile Charging Port Replacement: passo 2, imagem 1 %32 Osmo Mobile Charging Port Replacement: passo 2, imagem 2 %32
    • Use Phillips #00 screwdriver to remove the three screws found on the gimbal stabilizer to detach handle from gimbal.
    • Carefully detach handle from gimbal and disconnect the cable that connects the two.
  3. Osmo Mobile Charging Port Replacement: passo 3, imagem 1 %32
    • Locate the hex screws found at the top base of the handle, and unscrew using the 1.5mm hex screwdriver.
  4. Osmo Mobile Charging Port Replacement: passo 4, imagem 1 %32 Osmo Mobile Charging Port Replacement: passo 4, imagem 2 %32
    • Remove joystick by gently pulling away from handle
  5. Osmo Mobile Charging Port Replacement: passo 5, imagem 1 %32 Osmo Mobile Charging Port Replacement: passo 5, imagem 2 %32 Osmo Mobile Charging Port Replacement: passo 5, imagem 3 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Remove the quick release PCBA by locating the connecting wires and release the ribbon cable with tweezers.
    • Use the spudger to pry open and remove the face plate, starting at the back of the handle.
  6. Osmo Mobile Charging Port Replacement: passo 6, imagem 1 %32 Osmo Mobile Charging Port Replacement: passo 6, imagem 2 %32 Osmo Mobile Charging Port Replacement: passo 6, imagem 3 %32
    • Locate four screws directly on top of handle.
    • Unscrew the silver, bottom two screws, that are closest to the face plate using the 00 screwdriver.
    • Unscrew the black, top two screws, located furthest from the face plate, using the 0 screwdriver.
    • Remove the remaining two screws found on the front of the faceplate.
    • Remove the rest of the face plate shell.
  7. Osmo Mobile Charging Port Replacement, Charging Port: passo 7, imagem 1 %32
    • Remove the top left screw on the joystick panel with Phillips #00 screwdriver.
    • Lift faceplate holding joystick module.
  8. Osmo Mobile Charging Port Replacement: passo 8, imagem 1 %32
    • Remove the bottom right screw on the joystick panel with the #00 Phillips screwdriver.
  9. Osmo Mobile Charging Port Replacement: passo 9, imagem 1 %32
    • Hold down the larger of the two ribbon cables, and pull on circuit board with a constant and careful down and out motion.
  10. Osmo Mobile Charging Port Replacement: passo 10, imagem 1 %32
    • Remove the two screws from the green charging module and the two screws on the grey plate and remove from handle.
    • Replace charging module.
Conclusão
Equipe
USF Tampa, Team S2-G1, Nance Fall 2017 Membro de USF Tampa, Team S2-G1, Nance Fall 2017
USFT-NANCE-F17S2G1
Membros da 4
Autoria de 12 guias
3 comentários
Where can I buy a replacement port? Can’t find one with google.
patchdrury - Responder
Where can I buy the part. ?
John M O'Donovan - Responder
Which version Osmo Mobile is this for? I need one for ver. 3
Nick - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 27
Duração total: 2,807
