Ir para o conteúdo principal
Ortho Yard & Garden Sprayer Main Gasket Replacement
O que você precisa
    • Remove the main sprayer pump and take the gasket off. It is at the top of the threads. Try to save as much as you can to get the diameter.
  1. Ortho Yard & Garden Sprayer Main Gasket Replacement, Take the gasket to the hardware store: passo 2, imagem 1 %32
    • Go to the plumbing section and locate the washers. I found this particular washer in the toilet and bath tub section. The inner diameter can be a little smaller but it should have a similar width.
    • Replace the gasket.
Conclusão
For $2 you can have your sprayer going again.
Uma outra pessoa concluiu este guia.
Joe Bailey
Membro desde: 04/10/16
182 Reputação
Autoria de 1 guia
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 12
Últimos 30 dias: 26
Duração total: 2,408
