Introdução
Use this guide in order to replace the motherboard within the Oregon Scientific Meep! X2.
O que você precisa
Remove the orange covers from the left and right sides of the device by sliding up against the tabs.
Gently unhook the black security clips to loosen the ribbon cable. Use one of the plastic opening tools.
Pull lightly on the ribbon cable to remove it.
Use your spudger to separate the battery from the adhesive glue strips and plastic film.
Slip the plastic opening tool under the white, square enclosure of the camera and lift upward to unhook the camera unit from the motherboard.
Use your tweezers to gently remove the microphone from the slot in the casing.
Use a tweezer to gently pull the power button sensor out of the case's slot.
Undo the security clips on the ribbon cable connection by placing the plastic opening tool between the black and white parts of the clip. Pull downard toward the gold ribbon cable.
Once the left and right clips are undone, remove the gold ribbon cable from that connection by gently pulling it out.
