Ir para o conteúdo principal
Oregon Scientific Meep! 4.0 Microphone Replacement
O que você precisa
  1. Oregon Scientific Meep! 4.0 Microphone Replacement, Oregon Scientific Meep! 4.0 Disassembly: passo 1, imagem 1 %32
    • Use a screwdriver to remove the four 7.0 mm Philips #00 screws from the back of the device.
  2. Oregon Scientific Meep! 4.0 Microphone Replacement: passo 2, imagem 1 %32
    • Use a plastic opening tool to detach the clips on the inside of the device.
  3. Oregon Scientific Meep! 4.0 Microphone Replacement, Microphone: passo 3, imagem 1 %32
    • Use a screwdriver to remove the three 7.0 mm Philips #00 screws and unscrew the motherboard.
  4. Oregon Scientific Meep! 4.0 Microphone Replacement: passo 4, imagem 1 %32
    • Use a plastic opening tool to release the three ribbon cables attached to the motherboard.
  5. Oregon Scientific Meep! 4.0 Microphone Replacement: passo 5, imagem 1 %32 Oregon Scientific Meep! 4.0 Microphone Replacement: passo 5, imagem 2 %32
    • Lift up the motherboard and use a soldering station to remove the microphone from its wires.
Conclusão
Jess Forte
Membro desde: 09/25/15
434 Reputação
Autoria de 4 guias
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 7
Duração total: 174
