Ir para o conteúdo principal
Orbic Wonder Speaker Replacement
O que você precisa
  1. Orbic Wonder Speaker Replacement, Battery: passo 1, imagem 1 %32 Orbic Wonder Speaker Replacement, Battery: passo 1, imagem 2 %32 Orbic Wonder Speaker Replacement, Battery: passo 1, imagem 3 %32
    • Remove two 2mm TR9 Torx screws from the bottoms of the device.
  2. Orbic Wonder Speaker Replacement: passo 2, imagem 1 %32 Orbic Wonder Speaker Replacement: passo 2, imagem 2 %32 Orbic Wonder Speaker Replacement: passo 2, imagem 3 %32
    • There is a border between the black phone backing and the silver screen.
    • Place the Jimmy in this border, and cautiously torque it back and forth to part the two halves.
    • When the halves are parted correctly, the gap should look like this.
    • Be careful to avoid damaging any connecting circuitry between the two halves.
  3. Orbic Wonder Speaker Replacement: passo 3, imagem 1 %32 Orbic Wonder Speaker Replacement: passo 3, imagem 2 %32 Orbic Wonder Speaker Replacement: passo 3, imagem 3 %32
    Ferramenta utilizada nesse passo:
    Anti-Static Wrist Strap
    $7.95
    Comprar
    • Before continuing, tighten the anti-static wrist strap around your wrist and connect the alligator clips to a metal portion of the phone.
    • On the upper right side, there is a black ribbon cable in the shape of an “L”. Remove the single 1 mm Phillips #000 screw on the left side of the ribbon cable.
  4. Orbic Wonder Speaker Replacement: passo 4, imagem 1 %32 Orbic Wonder Speaker Replacement: passo 4, imagem 2 %32 Orbic Wonder Speaker Replacement: passo 4, imagem 3 %32
    • Use a pair of angled tweezers to carefully remove the metal casing of the ribbon cable.
    • Use a pair of angled tweezers to detach the black ribbon cable. This is done to unplug the battery.
  5. Orbic Wonder Speaker Replacement: passo 5, imagem 1 %32 Orbic Wonder Speaker Replacement: passo 5, imagem 2 %32 Orbic Wonder Speaker Replacement: passo 5, imagem 3 %32
    • There is a black flap on the bottom of the battery.
    • Using your fingers, pinch this flap and carefully pull the battery up and out of the phone.
  6. Orbic Wonder Speaker Replacement, Speaker: passo 6, imagem 1 %32 Orbic Wonder Speaker Replacement, Speaker: passo 6, imagem 2 %32 Orbic Wonder Speaker Replacement, Speaker: passo 6, imagem 3 %32
    $7.95
    Comprar
    • Remove the anti-static wrist strap.
    • Use the Phillips #000 screwdriver to remove the five black 2 mm screws.
    • Use the Phillips #000 screwdriver to remove the two grey 2 mm screws.
  7. Orbic Wonder Speaker Replacement: passo 7, imagem 1 %32 Orbic Wonder Speaker Replacement: passo 7, imagem 2 %32
    • Use a pair of angled tweezers to remove the speaker housing.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 11
Duração total: 439
