Ir para o conteúdo principal
Oral-B Vitality Power Button Replacement
O que você precisa
  1. Oral-B Vitality Power Button Replacement, Power Button: passo 1, imagem 1 %32 Oral-B Vitality Power Button Replacement, Power Button: passo 1, imagem 2 %32 Oral-B Vitality Power Button Replacement, Power Button: passo 1, imagem 3 %32
    • Using the pliers, rotate the head base 90 degrees counterclockwise and remove core from the handle.
  2. Oral-B Vitality Power Button Replacement: passo 2, imagem 1 %32
    • Locate the 4 terminals connecting the power button to the circuit board.
  3. Oral-B Vitality Power Button Replacement: passo 3, imagem 1 %32 Oral-B Vitality Power Button Replacement: passo 3, imagem 2 %32 Oral-B Vitality Power Button Replacement: passo 3, imagem 3 %32
    • Desolder the 4 terminals and remove the old button.
    • Remove as much of the old solder as possible.
  4. Oral-B Vitality Power Button Replacement: passo 4, imagem 1 %32
    • Attach the new button by soldering the 4 terminals with new solder.
Conclusão
8 outras pessoas executaram este guia.
Grady Bennett
Membro desde: 11/07/17
500 Reputação
Autoria de 2 guias
Equipe
IUPUI, Team S2-G1, Harley Fall 2017 Membro de IUPUI, Team S2-G1, Harley Fall 2017
IUPUI-HARLEY-F17S2G1
Membros da 3
Autoria de 8 guias
4 comentários
In my case no need to change the button, just redo the solder and this is it.
the vibration has damaged the solder.
Al kri - Responder
If you try to unsolder the battery it has some protection and it won't work anymore
Gigi Kent - Responder
Before unsoldering the button, you can understand if it is good or not just bypassing it with a wire: with a copper wire you can touch two pins of the button (one on the right side, on on the left side); if the toothbrush starts and stop on each touch of the wire, the problem is the button. I recognize the problem in this way.
Manolo Cerello - Responder
True except if the switch is permanently “on”. I think that was my case. Replacing the switch fixed the issue.
Mumble Tim -
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 9
Últimos 7 dias: 47
Últimos 30 dias: 183
Duração total: 9,648
