Ir para o conteúdo principal
Optoma HD72 Projection Lamp Replacement
O que você precisa
  1. Optoma HD72 Projection Lamp Replacement, Projection Lamp: passo 1, imagem 1 %32
    • Use a Phillips screwdriver to loosen the single captive 2 mm screw that secures the small lamp panel on the lower case.
    • Remove the panel.
  2. Optoma HD72 Projection Lamp Replacement: passo 2, imagem 1 %32
    • Use a Phillips screwdriver to loosen the two 2 mm screws on the bottom of the projection lamp housing.
  3. Optoma HD72 Projection Lamp Replacement: passo 3, imagem 1 %32 Optoma HD72 Projection Lamp Replacement: passo 3, imagem 2 %32
    • Lift the panel off of the device using the metal handle.
    • Disconnect the pink wires from the black plastic housing.
  4. Optoma HD72 Projection Lamp Replacement: passo 4, imagem 1 %32 Optoma HD72 Projection Lamp Replacement: passo 4, imagem 2 %32 Optoma HD72 Projection Lamp Replacement: passo 4, imagem 3 %32
    • Use a Phillips #2 screwdriver to remove the four 2 mm screws that secure the lamp to its housing.
    • Remove the projection lamp casing by gently lifting the bulb from its housing.
  5. Optoma HD72 Projection Lamp Replacement: passo 5, imagem 1 %32 Optoma HD72 Projection Lamp Replacement: passo 5, imagem 2 %32
    • Once the bulb is out, replace it with another bulb and re-secure the housings in reverse order to this guide.
    • The second photo is what the completed bulb housing should look like.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 11
Duração total: 43
