Ir para o conteúdo principal
Optoma HD72 Power Supply Replacement
O que você precisa
  1. Optoma HD72 Power Supply Replacement, Upper Case: passo 1, imagem 1 %32 Optoma HD72 Power Supply Replacement, Upper Case: passo 1, imagem 2 %32
    • Use a Phillips screwdriver to remove the five 2 mm screws on the underside of the device.
  2. Optoma HD72 Power Supply Replacement: passo 2, imagem 1 %32
    • Flip the device over and slightly lift the upper case, with care not to strain the two cables.
    • Disconnect the two cables that connect the top case to the motherboard.
    • Lift the upper case up and off.
  3. Optoma HD72 Power Supply Replacement, Power Supply: passo 3, imagem 1 %32 Optoma HD72 Power Supply Replacement, Power Supply: passo 3, imagem 2 %32 Optoma HD72 Power Supply Replacement, Power Supply: passo 3, imagem 3 %32
    • Remove the four 2 mm Phillips screws that secure the motherboard.
    • Remove the detachable wire bundles that connect to the ballast supply.
  4. Optoma HD72 Power Supply Replacement: passo 4, imagem 1 %32 Optoma HD72 Power Supply Replacement: passo 4, imagem 2 %32 Optoma HD72 Power Supply Replacement: passo 4, imagem 3 %32
    • Remove the four 2 mm Phillips #2 screws that secure the power supply.
    • Remove the 2 2.0mm Phillips #2 screws that secure the ballast to the power supply using a Phillips #2 screwdriver
    • Disconnect all of the ballast connections.
    • Lift the ballast out of the device.
  5. Optoma HD72 Power Supply Replacement: passo 5, imagem 1 %32 Optoma HD72 Power Supply Replacement: passo 5, imagem 2 %32 Optoma HD72 Power Supply Replacement: passo 5, imagem 3 %32
    • Remove the two Phillips screws that secure the power supply.
    • Disconnect the ballast from the power supply.
    • Remove the power supply.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 17
Duração total: 41
