Ir para o conteúdo principal
Optoma HD72 Color Wheel Replacement
O que você precisa
  1. Optoma HD72 Color Wheel Replacement, Upper Case: passo 1, imagem 1 %32 Optoma HD72 Color Wheel Replacement, Upper Case: passo 1, imagem 2 %32
    • Use a Phillips screwdriver to remove the five 2 mm screws on the underside of the device.
  2. Optoma HD72 Color Wheel Replacement: passo 2, imagem 1 %32
    • Flip the device over and slightly lift the upper case, with care not to strain the two cables.
    • Disconnect the two cables that connect the top case to the motherboard.
    • Lift the upper case up and off.
  3. Optoma HD72 Color Wheel Replacement, Motherboard: passo 3, imagem 1 %32 Optoma HD72 Color Wheel Replacement, Motherboard: passo 3, imagem 2 %32 Optoma HD72 Color Wheel Replacement, Motherboard: passo 3, imagem 3 %32
    • Disconnect all of the cables that are connected to the motherboard.
  4. Optoma HD72 Color Wheel Replacement: passo 4, imagem 1 %32
    • Remove the four 2 mm Phillips screws that secure the motherboard.
    • Lift the motherboard up and out of the chassis.
  5. Optoma HD72 Color Wheel Replacement, Color Wheel: passo 5, imagem 1 %32 Optoma HD72 Color Wheel Replacement, Color Wheel: passo 5, imagem 2 %32 Optoma HD72 Color Wheel Replacement, Color Wheel: passo 5, imagem 3 %32
    • Remove the three 2 mm Phillips screws that secure the black housing.
    • Lift the black housing off.
  6. Optoma HD72 Color Wheel Replacement: passo 6, imagem 1 %32 Optoma HD72 Color Wheel Replacement: passo 6, imagem 2 %32
    • Remove the single 2 mm Phillips screw that secures the color wheel.
    • Lift the color wheel up and out of its housing.
  7. Optoma HD72 Color Wheel Replacement: passo 7, imagem 1 %32 Optoma HD72 Color Wheel Replacement: passo 7, imagem 2 %32 Optoma HD72 Color Wheel Replacement: passo 7, imagem 3 %32
    • Remove the single 2 mm Phillips screw that secures the circuit board to the side of the color wheel.
    • Use a sharp tool to cut the zip tie that secures the color wheel’s cables.
    • Remove the color wheel.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 19
Duração total: 39
