Introdução
Use this guide to remove the light bulb from your Optoma HD20.
O que você precisa
Use a Phillips #1 screwdriver to loosen the screws that secure the panel on the bottom of the Optoma HD20.
Use a Phillips #1 screwdriver to loosen the two screws securing the black casing.
7 outras pessoas executaram este guia.
5 comentários
king@okinlamps.com
Need LAD60 20PCS
The manual says the new light won’t come back on until a lamp reset I’d done via menu , but how can you see the text if the light isn’t on?????
