Introdução
Use this guide to remove the fan from your Optoma HD20.
O que você precisa
Twist the focal cap clockwise until it is fully extended.
Remove the focal cap by pulling it straight out.
6 outras pessoas executaram este guia.
6 comentários
Very nice set of instructions! Excellent images and identification of items to remove. Thank you!
Do you know where to get this fan for replacement? Having trouble finding a parts list.
Small fan is GB1245PKVX-8, large fan is KDE1285PTV1
I am trying to determine if the fan works or not. Should the fan come on when there is no bulb in the projector? I removed the bulb when it burned up and I am not sure whether it was due to a failed fan or simply the bulb.
Amazing! Thank you!!! Took a bit of effort to get the fan but in the end it worked like a charm!! Thank you for saving money!!!!
