Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
Twist the focal cap clockwise until it is fully extended.
Remove the focal cap by pulling it straight out.
Use a Phillips #1 screwdriver to remove the three 7.5mm screws on the bottom of the device.
Use a plastic opening tool to gently pry the top cover off of the device.
Remove the ribbon by disconnecting it from the main circuit board.
Lift up the clip holding it down and pull the ribbon out.
Use a Phillips #1 screwdriver to remove the 5.5 mm screws around the pin wheel.
Use a Phillips #1 screwdriver to remove 1 more 5.5 mm screw.
Using a flat head screw driver unscrew the back part to release the color wheel.
Once unscrewed, remove the color wheel, and replace the part.
6 outras pessoas executaram este guia.
3 comentários
I've seen 5 guides say that the lens adjustment cover just pulls straight out, but even with significant force, it doesn't budge. Are there two different versions of the HD20 with two different designs for the cover?
I couldn't get the shroud off until I had the plastic top of the projector mostly off.
dlwalter -
The shroud has clips on it that attach to some bolts coming off the lense so yeah, it will take some force to pop the clips.
dlwalter -
