Ir para o conteúdo principal
Introdução
Use this guide to remove the color wheel from your Optoma HD20.
Peças
Nenhum componente especificado.
  1. Twist the focal cap clockwise until it is fully extended. Remove the focal cap by pulling it straight out.
    • Twist the focal cap clockwise until it is fully extended.
    • Remove the focal cap by pulling it straight out.
  2. Use a Phillips #1 screwdriver to remove the three 7.5mm screws on the bottom of the device.
    • Use a Phillips #1 screwdriver to remove the three 7.5mm screws on the bottom of the device.
  3. Use a plastic opening tool to gently pry the top cover off of the device.
    • Use a plastic opening tool to gently pry the top cover off of the device.
    • It is easier to pry off the cover from the back side just above the HDMI ports.
  4. When removing the cover, be cautious of the ribbon connecting the top buttons to the main circuit board. The ribbon must be disconnected before proceeding.
    • When removing the cover, be cautious of the ribbon connecting the top buttons to the main circuit board. The ribbon must be disconnected before proceeding.
    • Remove the ribbon by disconnecting it from the main circuit board.
    • Lift up the clip holding it down and pull the ribbon out.
  5. Use the plastic opening tool to remove the wiring.
    • Use the plastic opening tool to remove the wiring.
  6. Use a Phillips #1 screwdriver to remove the 5.5 mm screws around the pin wheel.
    • Use a Phillips #1 screwdriver to remove the 5.5 mm screws around the pin wheel.
  7. Use a Phillips #1 screwdriver to remove 1 more 5.5 mm screw.
    • Use a Phillips #1 screwdriver to remove 1 more 5.5 mm screw.
  8. Using a flat head screw driver unscrew the back part to release the color wheel.
    • Using a flat head screw driver unscrew the back part to release the color wheel.
    • Do this carefully because these screws do not pull out.
  9. Once unscrewed, remove the color wheel, and replace the part.
    • Once unscrewed, remove the color wheel, and replace the part.
Conclusão
3 outras pessoas concluíram este guia.
Trever
Membro desde: 22/01/2015
1.121 Reputação
6 Guias de autoria
Equipe
Cal Poly, Team 21-23, Maness Winter 2015 Membro de Cal Poly, Team 21-23, Maness Winter 2015
CPSU-MANESS-W15S21G23
4 Membros
6 Guias de autoria
4 comentários
I've seen 5 guides say that the lens adjustment cover just pulls straight out, but even with significant force, it doesn't budge. Are there two different versions of the HD20 with two different designs for the cover?
srbaucom - Responder
I couldn't get the shroud off until I had the plastic top of the projector mostly off.
dlwalter -
The shroud has clips on it that attach to some bolts coming off the lense so yeah, it will take some force to pop the clips.
dlwalter -
It literally pops off. It has 3 slips on it but they all undo at the same time you pull it straight out.
Vincent Felix - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 11
Últimos 30 dias: 64
Duração total: 7,239
