Ir para o conteúdo principal
Opening the Hood
  1. Opening the Hood, Opening the Hood: passo 1, imagem 1 %32 Opening the Hood, Opening the Hood: passo 1, imagem 2 %32
    • Locate the hood latch beside the driver's side door, next to the left foot rest.
    • Pull the latch toward you to release the hood.
  2. Opening the Hood: passo 2, imagem 1 %32 Opening the Hood: passo 2, imagem 2 %32
    • Walk around to the front of the vehicle.
    • Slide your hand under the hood, directly above the Honda emblem. Locate and pull the hood tab to unlock the hood.
    • Once the tab is released, lift the hood up.
  3. Opening the Hood: passo 3, imagem 1 %32 Opening the Hood: passo 3, imagem 2 %32
    • Use your left hand to hold the hood up. Locate the hood stand and pull it out of the clip.
    • Place the tip of the hood stand into the hole located in the upper left of the hood.
    • You can now let the hood rest on the stand.
Conclusão
6 outras pessoas executaram este guia.
Shaun MacDonald
Membro desde: 10/03/12
2.654 Reputação
Autoria de 8 guias
Equipe
Cal Poly, Team 24-27, Regan Fall 2012 Membro de Cal Poly, Team 24-27, Regan Fall 2012
CPSU-REGAN-F12S24G27
4 Membros
Autoria de 24 guias
1Comentário do guia
Whats next after opening the hood? How to check for the hood latch? Where is it located? Need to check for the cause why the alarm keeps going
off at odd hours. The car has lojack and a car alarm. Changed the FOB key that didnt worked. Manually opened the door with key. Not happening problem still exist. Need help with what other options.
boomanison - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 39
Últimos 7 dias: 268
Últimos 30 dias: 1,367
Ao todo: 80,877
