Ir para o conteúdo principal
Opening the Galaxy Watch3
O que você precisa
  1. Opening the Galaxy Watch3, Unfasten the back cover screws: passo 1, imagem 1 %32
    • Before starting repairs, take your watch off the charger and power it down.
    • Use a Tri-point Y00 driver to unfasten the four screws on the back of the watch.
    • Don’t worry about removing the screws, they will stay in place in the back cover.
  2. Opening the Galaxy Watch3, Wedge open the back cover: passo 2, imagem 1 %32 Opening the Galaxy Watch3, Wedge open the back cover: passo 2, imagem 2 %32
    • Insert an opening tool between the back cover and the metal housing.
    • Twist the opening tool to create a wider gap.
    • Don't fully remove the back cover just yet. The sensor flex cable is still connected to the motherboard.
  3. Opening the Galaxy Watch3, Disconnect the sensor flex cable: passo 3, imagem 1 %32 Opening the Galaxy Watch3, Disconnect the sensor flex cable: passo 3, imagem 2 %32 Opening the Galaxy Watch3, Disconnect the sensor flex cable: passo 3, imagem 3 %32
    • Lay the watch face down.
    • Carefully lift the back cover up from the edge with the buttons to access the sensor connector.
    • Use the flat end of a spudger to pry up and disconnect the sensor flex cable from the motherboard.
  4. Opening the Galaxy Watch3, Remove the back cover: passo 4, imagem 1 %32 Opening the Galaxy Watch3, Remove the back cover: passo 4, imagem 2 %32
    • Remove the back cover.
    • Make sure the rubber gasket (marked red) is undamaged. If damaged replace it with a new one during reassembly to maintain proper water resistance.
Conclusão
Uma outra pessoa concluiu este guia.
Tobias Isakeit
Membro desde: 03/31/14
117.763 Reputação
Autoria de 188 guias
Equipe
Master Techs Membro de Master Techs
Community
Membros da 322
Autoria de 2.545 guias
3 comentários
where can I get the galaxy watch3 rubber gasket?
regards
Miguel Vera - Responder
That’s a good question. As for the previous models it is very hard to find those rubber gaskets. Using a “liquid rubber gasket” might be one solution to that. (Use carefully to not spill too much on and into the watch)
Tobias Isakeit -
I tried to remove all of the screws from the back cover, but 3 of the 4 screws remained and seemed to be fused to the main base of the watch. One of the screws was stripped. Now only 1 screw is engaged with the back cover. (I might need to replace the back cover. My watch is glitching which is draining the battery. I would like to fix the problems myself. Where can I get specific advice?
Antoinette - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 15
Últimos 30 dias: 72
Duração total: 2,298
