Ir para o conteúdo principal
Opening the Column in the Hamilton Galileo
O que você precisa
  1. Opening the Column in the Hamilton Galileo, Opening the Column in the Hamilton Galileo: passo 1, imagem 1 %32
    • Use a grounding cable and wrist band connected to the GALILEO or other work surface when you are working on the GALILEO.
    • Remove from GALILEO: External mains power supply, Air and oxygen supplies, Patient breathing circuit (for convenience only), Flow Sensor tubes (for convenience only).
  2. Opening the Column in the Hamilton Galileo: passo 3, imagem 1 %32
    • Loosen the rear panel of the column by removing the six hexagonal-drive (Allen) screws that hold it in place.
  3. Opening the Column in the Hamilton Galileo: passo 4, imagem 1 %32 Opening the Column in the Hamilton Galileo: passo 4, imagem 2 %32
    • Without removing any electrical connections, open the left side of the column as wide as practical.
    • This exposes: GALILEO’s internal power supply, The battery fuse, The diagnostic LEDs on the power supply’s main circuit board, and the back up batteries.
    • Make sure no electrical connections are touching the column.
    • Make sure all green/brown grounding (earthing) cables are securely in place.
Conclusão
Ian Van Sciver
Membro desde: 04/09/20
332 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team S7-G26, Paton Spring 2020 Membro de Cal Poly, Team S7-G26, Paton Spring 2020
CPSU-PATON-S20S7G26
Membros da 3
Autoria de 4 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 3
Duração total: 117
