Ir para o conteúdo principal
OontZ Angle 3 Motherboard Replacement
O que você precisa
  1. OontZ Angle 3 Motherboard Replacement, Back Case: passo 1, imagem 1 %32 OontZ Angle 3 Motherboard Replacement, Back Case: passo 1, imagem 2 %32 OontZ Angle 3 Motherboard Replacement, Back Case: passo 1, imagem 3 %32
    • Make sure that the OontZ Angle 3 is powered off before starting the disassembly.
    • Use the plastic opening tool to remove the rubber caps from each end of the speaker.
  2. OontZ Angle 3 Motherboard Replacement: passo 2, imagem 1 %32
    • Remove four (4) 11.7 mm Phillips #0 screws from each side at the bottom of the speaker.
  3. OontZ Angle 3 Motherboard Replacement: passo 3, imagem 1 %32 OontZ Angle 3 Motherboard Replacement: passo 3, imagem 2 %32
    • Use the plastic opening tool on one of the corners to separate the bottom piece from the speaker, and then remove the piece.
  4. OontZ Angle 3 Motherboard Replacement, Motherboard: passo 4, imagem 1 %32 OontZ Angle 3 Motherboard Replacement, Motherboard: passo 4, imagem 2 %32 OontZ Angle 3 Motherboard Replacement, Motherboard: passo 4, imagem 3 %32
    • Locate the soldering connections for the battery on the motherboard and the wires for the speakers.
    • Use the soldering iron to disconnect the battery wires from the motherboard.
    • Use the soldering iron to disconnect the speaker wires from the motherboard.
    • When reconnecting the battery and speakers to the new motherboard, be careful to make the connections to the correct nodes as well as establish a complete connection, as the speakers could break with an incorrect connection and the battery risks overheating or erupting in flames if corrected incorrectly or poorly.
  5. OontZ Angle 3 Motherboard Replacement: passo 5, imagem 1 %32 OontZ Angle 3 Motherboard Replacement: passo 5, imagem 2 %32 OontZ Angle 3 Motherboard Replacement: passo 5, imagem 3 %32
    • Remove the three (3) 3.6mm screws using a Phillips #0 screwdriver.
    • Use the plastic opening tool about midway down one side of the motherboard to pry it out of the casing.
    • Remove the faulty motherboard.
Conclusão
7 outras pessoas executaram este guia.
Mason Hollander
Membro desde: 01/20/16
1.387 Reputação
Autoria de 4 guias
Equipe
USF Tampa, Team 15-6, Remmell Spring 2016 Membro de USF Tampa, Team 15-6, Remmell Spring 2016
USFT-REMMELL-S16S15G6
Membros da 4
Autoria de 4 guias
15 comentários
where do i buy mother board of oontz angle 3?
Jomar Agcaoili - Responder
how much does a new motherboard cost??
Linda Coppola - Responder
Can you post where to get a new MB?
Brian Dickert - Responder
It does require a part...the new motherboard!
I'm having a hard time tracking down motherboards too. But the guide is still helpful if someone wants to harvest a motherboard out of another broken Oontz and use it in their own. If anyone else finds a source for the motherboard, feel free to edit the guide and include a link to it in the details section. Maybe if we all work together we can find a source.
Kelsea Weber - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 9
Últimos 30 dias: 48
Duração total: 12,154
