Ir para o conteúdo principal
OontZ Angle 3 Motherboard Replacement
O que você precisa
  1. OontZ Angle 3 Motherboard Replacement, Back Case: passo 1, imagem 1 %32 OontZ Angle 3 Motherboard Replacement, Back Case: passo 1, imagem 2 %32 OontZ Angle 3 Motherboard Replacement, Back Case: passo 1, imagem 3 %32
    • Make sure that the OontZ Angle 3 is powered off before starting the disassembly.
    • Use the plastic opening tool to remove the rubber caps from each end of the speaker.
    Pergunte ao FixBot
  2. OontZ Angle 3 Motherboard Replacement: passo 2, imagem 1 %32
    • Remove four (4) 11.7 mm Phillips #0 screws from each side at the bottom of the speaker.
    Pergunte ao FixBot
  3. OontZ Angle 3 Motherboard Replacement: passo 3, imagem 1 %32 OontZ Angle 3 Motherboard Replacement: passo 3, imagem 2 %32
    • Use the plastic opening tool on one of the corners to separate the bottom piece from the speaker, and then remove the piece.
    Pergunte ao FixBot
  4. OontZ Angle 3 Motherboard Replacement, Motherboard: passo 4, imagem 1 %32 OontZ Angle 3 Motherboard Replacement, Motherboard: passo 4, imagem 2 %32 OontZ Angle 3 Motherboard Replacement, Motherboard: passo 4, imagem 3 %32
    • Locate the soldering connections for the battery on the motherboard and the wires for the speakers.
    • Use the soldering iron to disconnect the battery wires from the motherboard.
    • Use the soldering iron to disconnect the speaker wires from the motherboard.
    • When reconnecting the battery and speakers to the new motherboard, be careful to make the connections to the correct nodes as well as establish a complete connection, as the speakers could break with an incorrect connection and the battery risks overheating or erupting in flames if corrected incorrectly or poorly.
    Pergunte ao FixBot
  5. OontZ Angle 3 Motherboard Replacement: passo 5, imagem 1 %32 OontZ Angle 3 Motherboard Replacement: passo 5, imagem 2 %32 OontZ Angle 3 Motherboard Replacement: passo 5, imagem 3 %32
    • Remove the three (3) 3.6mm screws using a Phillips #0 screwdriver.
    • Use the plastic opening tool about midway down one side of the motherboard to pry it out of the casing.
    • Remove the faulty motherboard.
    Pergunte ao FixBot
Conclusão
9 outras pessoas executaram este guia.
Mason Hollander
Membro desde: 01/20/16
1.604 Reputação
Autoria de 4 guias
Equipe
USF Tampa, Team 15-6, Remmell Spring 2016 Membro de USF Tampa, Team 15-6, Remmell Spring 2016
USFT-REMMELL-S16S15G6
4 Membros
Autoria de 4 guias
15Comentários do guia
where do i buy mother board of oontz angle 3?
Jomar Agcaoili - Responder Compartilhar
how much does a new motherboard cost??
Linda Coppola - Responder Compartilhar
Can you post where to get a new MB?
Brian Dickert - Responder Compartilhar
It does require a part...the new motherboard!
I'm having a hard time tracking down motherboards too. But the guide is still helpful if someone wants to harvest a motherboard out of another broken Oontz and use it in their own. If anyone else finds a source for the motherboard, feel free to edit the guide and include a link to it in the details section. Maybe if we all work together we can find a source.
Kelsea Weber - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 14
Últimos 30 dias: 78
Ao todo: 13,750
