Introdução
This replacement guide will demonstrate how to replace a fuse in an Onkyo TX-800.
A fuse is an electrical safety device that protects the circuit board in the event that there is excessive current.
Before doing anything, make sure to safely discharge the capacitor using this guide.
O que você precisa
Remove the two screws on both sides of the receiver. Keep these and the rest of the screws in a safe place.
Examine the fuse. If the wire within it is broken, you will need to replace it with a new 125 Volt, 4 Amp fuse.
5 outras pessoas executaram este guia.
2 comentários
Thanks for clear instructions!
