Introdução
Problem: CD playing problems as cracking, fas-forwarding, lack of bass...
Problem can be solved by cleaning the laser lense.
O que você precisa
Remove the data cable from the amplifier by pulling during pressing the plug on both sides
Remove the 4 crews on the sides and the 3 screws on the back to remove the cover
Ferramenta utilizada nesse passo:Microfiber Cleaning Cloths$3.99
Take a microfiber cloth or any clean cloth which is lint-free
Wrap it around a flat screwdriver and soak it with high-percentage cleaning alcohol. I used 80% alcohol and it worked fine
Clean gently and carefully the lense
Turn the laser back to its standard position with the gearwheel
