Introdução
The guide will show you how to replace the micro USB charging port located on the bottom edge of the phone.
O que você precisa
Power off the phone by pressing the button on the right side of the phone, it will be the smaller button.
Press and hold the button down for a few seconds, until the option "Power Off" appears on the screen.
Select "Power Off" on the screen to turn off the phone.
Using a heat gun, apply slow and even heat to the edges of the back panel.
While heating the back panel, use a Jimmy to test if the adhesive is soft enough to allow the panel to separate from the device.
Carefully detach the back panel, using opening picks to hold the panel apart from the device.
Once most of the edges are separated from the device, attach a suction cup to the back panel.
Using a PH000 screwdriver, remove the following seven screws circled with red and orange:
Four (longer) PH000 screws
Three shorter PH000 screws
Once all of the screws are removed, proceed to using a plastic spudger to pry the metal cover off.
There are two clips near the bottom, right above the battery, so start by prying on the bottom edge of the plate.
Using a PH #000 screwdriver, remove the 8 screws from the motherboard, circled red in the diagram.
Once all the screws have been removed, use the plastic spudger to pry the metal cover off.
After removing the Phillips head screw, you will need to remove a black wire. Use a spudger to unclip the cable first.
Pull back on the ribbon-cable as shown in the image. This is connected to both the charging port and the vibration module (which is similar to a small watch battery).
Gently pry the vibration module out with a plastic opening tool. Be gentle, for it is adhered to the phone.
15 outras pessoas executaram este guia.
7 comentários
I had to reuse the vibration motor de- and solder it back on, because it is not included in the spare part.
Watch for the silence switch when you reasamble the phone. I had to unscrew the upper bord again because i didn't payed atention to it and it was locked. Also the mic is covered on the replacement part. Don't forget to remove the yellow "flag" there.
I replaced USB flex port, now working, but now phone dont recognize SIM card..what i must check? Thanks for any help
What is the price of charging port with vibrator module
Good Instructions
In the upper right Corner is one more Screw
where the Logic-board is screwed directly.
That was not mentioned!
Also, you should pay attention that you do not pry where the PCP goes around the Camera.
I break off the Corner, fortunately it's only connected to the Status-LED.
Otherwise everything works.
