Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Introdução
This guide will show how to replace the motherboard of your OnePlus 6T. Make sure to use the correct tools and to be careful after removing the back cover of the device.
O que você precisa
Make sure the phone is powered off and placed with the back cover facing towards you on a stable surface.
Ferramenta utilizada nesse passo:Plastic Cards$2.99
Insert a Jimmy under one of the heated corners of the phone to lift it slightly.
Insert a plastic card underneath the slightly lifted lip on the back cover and gently glide the card under the lifted phone casing.
Remove the back cover from the phone.
Remove the single 3mm Phillips #00 screws holding the metal battery cover on the phone.
Use tweezers to remove the battery cover and place it to the side.
Remove the single 3mm Phillips #00 screw to the right of the top rear camera.
3 outras pessoas executaram este guia.
