Ir para o conteúdo principal
OnePlus 5T Back Cover Replacement
O que você precisa
  1. OnePlus 5T Back Cover Replacement, Back Cover: passo 1, imagem 1 %32 OnePlus 5T Back Cover Replacement, Back Cover: passo 1, imagem 2 %32
    • Before you begin, switch off your phone.
    • Remove the SIM card tray.
  2. OnePlus 5T Back Cover Replacement: passo 2, imagem 1 %32
    • Remove the two Torx T2 screws (2.5 mm length).
    • The OnePlus 5T doesn't use a lot of adhesive to secure the backcover, however the clamps are very strong and require some force during the opening procedure.
  3. OnePlus 5T Back Cover Replacement: passo 3, imagem 1 %32 OnePlus 5T Back Cover Replacement: passo 3, imagem 2 %32 OnePlus 5T Back Cover Replacement: passo 3, imagem 3 %32
    • Insert an opening tool between the display and the backcover at the bottom end of the phone.
    • Use the opening tool to create a gap between back cover and display.
    • Insert an opening pick in the gap you created with the opening tool.
  4. OnePlus 5T Back Cover Replacement: passo 4, imagem 1 %32 OnePlus 5T Back Cover Replacement: passo 4, imagem 2 %32 OnePlus 5T Back Cover Replacement: passo 4, imagem 3 %32
    • Slide the opening pick to the bottom right corner of the phone.
    • Insert a second opening pick and slide it to the bottom left corner of the phone.
  5. OnePlus 5T Back Cover Replacement: passo 5, imagem 1 %32 OnePlus 5T Back Cover Replacement: passo 5, imagem 2 %32 OnePlus 5T Back Cover Replacement: passo 5, imagem 3 %32
    • Slide the opening pick around the bottom left corner and then up along the left edge of the phone to open the plastic clamps that secure the backcover.
  6. OnePlus 5T Back Cover Replacement: passo 6, imagem 1 %32 OnePlus 5T Back Cover Replacement: passo 6, imagem 2 %32 OnePlus 5T Back Cover Replacement: passo 6, imagem 3 %32
    • Slide the opening pick around the bottom right corner and then up along the right edge of the phone to open the plastic clamps that secure the backcover.
  7. OnePlus 5T Back Cover Replacement: passo 7, imagem 1 %32 OnePlus 5T Back Cover Replacement: passo 7, imagem 2 %32 OnePlus 5T Back Cover Replacement: passo 7, imagem 3 %32
    • Try not to remove the backcover all the way yet. The fingerprint and the charging port and headphone flex cables are still connected to the motherboard.
    • Flip your phone and carefully lift the bottom end of the backcover away from the phone assembly. Fold it to left and hold it at an 80° angle.
  8. OnePlus 5T Back Cover Replacement: passo 8, imagem 1 %32 OnePlus 5T Back Cover Replacement: passo 8, imagem 2 %32
    • Use a spudger to pry up and disconnect the fingerprint flex cable.
  9. OnePlus 5T Back Cover Replacement: passo 9, imagem 1 %32 OnePlus 5T Back Cover Replacement: passo 9, imagem 2 %32 OnePlus 5T Back Cover Replacement: passo 9, imagem 3 %32
    • Twist the backcover around 180° and lay it down to align the bottom end of the backcover the top edge of the battery.
  10. OnePlus 5T Back Cover Replacement: passo 10, imagem 1 %32 OnePlus 5T Back Cover Replacement: passo 10, imagem 2 %32 OnePlus 5T Back Cover Replacement: passo 10, imagem 3 %32
    Ferramenta utilizada neste passo:
    • Use a pair of tweezers to remove the small metal shield which covers the battery and the charging port and headphone jack flex cable connectors.
  11. OnePlus 5T Back Cover Replacement: passo 11, imagem 1 %32 OnePlus 5T Back Cover Replacement: passo 11, imagem 2 %32
    • Use a spudger to pry up and disconnect the charging port and headphone jack flex cable.
  12. OnePlus 5T Back Cover Replacement: passo 12, imagem 1 %32 OnePlus 5T Back Cover Replacement: passo 12, imagem 2 %32
    • Remove the backcover.
Conclusão
To reassemble your device, follow these instructions in reverse order. Apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
Repair didn’t go as planned? Check out our Answers Community for troubleshooting help.
6 outras pessoas executaram este guia.
Dominik Schnabelrauch
Membro desde: 11/23/16
257.353 Reputação
Autoria de 682 guias
Equipe
iFixit Membro de iFixit
Staff
123 Membros
Autoria de 25.577 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 4
Últimos 7 dias: 26
Últimos 30 dias: 83
Ao todo: 4,200
