Ir para o conteúdo principal
OnePlus 5 Earpiece Speaker Replacement
O que você precisa
  1. OnePlus 5 Earpiece Speaker Replacement, SIM Card Tray: passo 1, imagem 1 %32 OnePlus 5 Earpiece Speaker Replacement, SIM Card Tray: passo 1, imagem 2 %32 OnePlus 5 Earpiece Speaker Replacement, SIM Card Tray: passo 1, imagem 3 %32
    • Insert a SIM card eject tool, bit, or a straightened paperclip into the small hole below the SIM card tray, located near the rear cameras on the edge of the phone.
    • Press firmly to eject the tray.
    • During reassembly, be sure to properly orient the SIM tray you you insert it.
  2. OnePlus 5 Earpiece Speaker Replacement, Back Cover: passo 2, imagem 1 %32
    • Remove the two 2.6 mm T2 screws straddling the USB-C port on the bottom edge of the phone.
  3. OnePlus 5 Earpiece Speaker Replacement: passo 3, imagem 1 %32 OnePlus 5 Earpiece Speaker Replacement: passo 3, imagem 2 %32 OnePlus 5 Earpiece Speaker Replacement: passo 3, imagem 3 %32
    • There is a high risk of damaging the display panel if this opening procedure is improperly followed.
    • The following four steps show how to pry the rear case from the plastic frame. Read through the steps first before attempting the procedure.
    • There are two different seams between the body and the screen of the phone:
    • Display panel seam: This seam is part of the display assembly. Do not pry at this seam, or you will separate and damage the display panel.
    • Frame seam: This is where the plastic frame meets the back cover. Only pry at this seam.
    • There are twelve clips that hold the frame against the rear case. Be aware of their location as you pry the back cover off in the following steps.
  4. OnePlus 5 Earpiece Speaker Replacement: passo 4, imagem 1 %32 OnePlus 5 Earpiece Speaker Replacement: passo 4, imagem 2 %32
    • As you work, try not to accidentally power on the phone. If you do, turn the phone off before resuming disassembly.
    • Place a suction cup near the bottom edge of the display.
    • Pull on the suction cup with strong steady force.
    • Press the edge of an opening tool straight into the frame seam near the suction cup until the edge wedges between the plastic frame and the back cover's lip.
    • Due to tight tolerances, this will take substantial force. Using a new opening tool with an unmarred edge will help with this step.
  5. OnePlus 5 Earpiece Speaker Replacement: passo 5, imagem 1 %32 OnePlus 5 Earpiece Speaker Replacement: passo 5, imagem 2 %32 OnePlus 5 Earpiece Speaker Replacement: passo 5, imagem 3 %32
    • Once the opening tool's edge is wedged in position, carefully slide the tool along the bottom edge of the phone.
    • Carefully guide the opening tool around the left corner of the phone while keeping the tool's edge within the seam.
  6. OnePlus 5 Earpiece Speaker Replacement: passo 6, imagem 1 %32 OnePlus 5 Earpiece Speaker Replacement: passo 6, imagem 2 %32
    • Lever the opening tool to release the first clip from the frame.
  7. OnePlus 5 Earpiece Speaker Replacement: passo 7, imagem 1 %32 OnePlus 5 Earpiece Speaker Replacement: passo 7, imagem 2 %32 OnePlus 5 Earpiece Speaker Replacement: passo 7, imagem 3 %32
    • Continue sliding the opening tool along the long edge, releasing the clips along the way.
    • The last clip in the top-left corner near the front-facing camera is recessed and can be difficult to release. Take your time and use the flat end of a spudger or an opening pick to help.
  8. OnePlus 5 Earpiece Speaker Replacement: passo 8, imagem 1 %32
    • With the bottom and left edge of the phone freed, gently wiggle the frame to release the top and right edge clips.
    • The frame is still connected to the back cover by a long flex cable. Do not remove the back cover.
    • During reassembly, pause here to test your phone's functionality before securing the back cover.
    • To reinstall the back cover:
    • Align the top edge of the frame to the back cover and ensure that the top clips slip into place.
    • Squeeze along the long edges of the phone to snap the remaining clips into place.
  9. OnePlus 5 Earpiece Speaker Replacement: passo 9, imagem 1 %32 OnePlus 5 Earpiece Speaker Replacement: passo 9, imagem 2 %32 OnePlus 5 Earpiece Speaker Replacement: passo 9, imagem 3 %32
    • With all the clips released, flip the phone over so that the display is face-down.
    • Swing the back cover around and rest it on top of the exposed frame.
    • Be careful not to stress the flex cable connecting the back cover and the frame.
  10. OnePlus 5 Earpiece Speaker Replacement: passo 10, imagem 1 %32 OnePlus 5 Earpiece Speaker Replacement: passo 10, imagem 2 %32
    • Remove the 2.6 mm Phillips screw holding the cable bracket above the battery in place.
    • Lift up and remove the cable bracket.
    • To reinstall the bracket, position one end into place, and bend the bracket slightly to spring the other end into place.
  11. OnePlus 5 Earpiece Speaker Replacement: passo 11, imagem 1 %32 OnePlus 5 Earpiece Speaker Replacement: passo 11, imagem 2 %32
    • Use the point of a spudger to pry up and disconnect the back cover flex cable from its socket.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
  12. OnePlus 5 Earpiece Speaker Replacement: passo 12, imagem 1 %32
    • Remove the back cover.
  13. OnePlus 5 Earpiece Speaker Replacement, OnePlus 5 Battery Disconnect: passo 13, imagem 1 %32 OnePlus 5 Earpiece Speaker Replacement, OnePlus 5 Battery Disconnect: passo 13, imagem 2 %32
    • Use the point of a spudger to pry up and disconnect the battery connector from its socket.
  14. OnePlus 5 Earpiece Speaker Replacement, Loudspeaker: passo 14, imagem 1 %32
    • Remove the six 2.6 mm Phillips screws securing the loudspeaker to the frame.
  15. OnePlus 5 Earpiece Speaker Replacement: passo 15, imagem 1 %32 OnePlus 5 Earpiece Speaker Replacement: passo 15, imagem 2 %32
    • Insert the flat end of a spudger into the corner of the loudspeaker assembly and pry slightly, loosening the loudspeaker from its recess.
  16. OnePlus 5 Earpiece Speaker Replacement: passo 16, imagem 1 %32
    • Remove the loudspeaker.
    • To reinstall the loudspeaker, align the loudspeaker's bottom edge to the frame, then press the assembly into place.
    • During reinstallation, make sure that the display cable connector under the loudspeaker assembly is still securely fastened.
  17. OnePlus 5 Earpiece Speaker Replacement, OnePlus 5 Interconnect Cable Disconnect: passo 17, imagem 1 %32 OnePlus 5 Earpiece Speaker Replacement, OnePlus 5 Interconnect Cable Disconnect: passo 17, imagem 2 %32 OnePlus 5 Earpiece Speaker Replacement, OnePlus 5 Interconnect Cable Disconnect: passo 17, imagem 3 %32
    • Use the point of a spudger to pry up and disconnect the interconnect flex cable from the socket.
    • If you are replacing the battery, bend the interconnect flex cable away from the phone and secure it out of the way with a rubber band or tape.
  18. OnePlus 5 Earpiece Speaker Replacement, Motherboard: passo 18, imagem 1 %32 OnePlus 5 Earpiece Speaker Replacement, Motherboard: passo 18, imagem 2 %32
    • Use the point of a spudger to pry up and disconnect the display interconnect cable from its socket near the bottom edge of the motherboard.
  19. OnePlus 5 Earpiece Speaker Replacement: passo 19, imagem 1 %32 OnePlus 5 Earpiece Speaker Replacement: passo 19, imagem 2 %32
    • Slide the point of a spudger underneath the antenna interconnect cable that is connected to the motherboard above the vibration motor.
    • Pry up to disconnect the cable from its socket.
    • De-route the cable out of its motherboard grounding clip and move it out of the way.
  20. OnePlus 5 Earpiece Speaker Replacement: passo 20, imagem 1 %32 OnePlus 5 Earpiece Speaker Replacement: passo 20, imagem 2 %32
    • Slide the point of a spudger under the small square antenna connector connected to the motherboard near the top edge.
    • Pry up to disconnect the antenna connector from its socket.
  21. OnePlus 5 Earpiece Speaker Replacement: passo 21, imagem 1 %32
    • Remove the following seven 2.6 mm Phillips screws securing the motherboard:
    • Some screws may be hidden under stickers. Remove the stickers to access the screws.
  22. OnePlus 5 Earpiece Speaker Replacement: passo 22, imagem 1 %32 OnePlus 5 Earpiece Speaker Replacement: passo 22, imagem 2 %32 OnePlus 5 Earpiece Speaker Replacement: passo 22, imagem 3 %32
    • Use your fingers to lift up the top edge of the motherboard.
    • Lift the motherboard out of its recess and remove it.
  23. OnePlus 5 Earpiece Speaker Replacement, Earpiece Speaker: passo 23, imagem 1 %32 OnePlus 5 Earpiece Speaker Replacement, Earpiece Speaker: passo 23, imagem 2 %32
    • Insert the point of a spudger under the top right corner of the earpiece module and pry up, loosening the module from its recess.
  24. OnePlus 5 Earpiece Speaker Replacement: passo 24, imagem 1 %32
    • Remove the earpiece module.
    • During reinstallation, be sure that the earpiece module is properly oriented such that the gold contacts face downwards.
    • If you are transferring the earpiece module to a replacement frame, be sure to peel and remove the white adhesive liner before pressing the earpiece module into place.
Conclusão
Repair didn’t go as planned? Check out our OnePlus 5 Answers Community for troubleshooting help.
Arthur Shi
Membro desde: 01/03/18
252.690 Reputação
Autoria de 526 guias
Equipe
iFixit Membro de iFixit
Staff
Membros da 135
Autoria de 16.817 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 5
Últimos 30 dias: 17
Duração total: 1,932
